Old 11-05-2012, 06:30 PM   #1
brawas
Tire Pressure
Hi guys
I did some searching around and can't find a clear answer. I have a BMW 2008 328i Convertible (E93). The stock tires are 225/45/R17. I replaced them with 215/50/R17 for winter tires (Toyo Observe Garit KX). What I'm trying to figure out is the recommended tire pressure for these wheels on my car. The manual shows a variety of different sizes and recommendations, but nothing with 215 (most are 225 or 205).
The tires say 50psi max on them and I currently have them at 45psi all round. The reason I went so high is cause they looked low otherwise.
Any suggestions? Your help is appreciated.
brawas is offline   Reply With Quote
Old 11-05-2012, 07:34 PM   #2
Quack
Wheelman
Quack's Avatar
add 4psi to what the stock 225 tire pressures are for the winter, that's what dealers do.
Old 11-05-2012, 11:42 PM   #3
Blackedout95
As a general rule of thumb I like 35, not hard and not soft, nice good medium. Of course it's all up to feel for the driver, some insist on a firmer 40+psi.
You may also find tire wear differs at 35 vs 40 or more. That would take time to figure out and miles so... best to spend a week at 35 and then at 40 and see if you can tell any difference.
E46
Old 11-06-2012, 10:25 AM   #4
Zook@SCB
Run Factory Recomended Pressure.
Zook@SCB is offline   Reply With Quote
Old 10-26-2017, 07:08 AM   #5
DanielLee5
DanielLee5's Avatar
Have just the same question!!
DanielLee5 is offline   Reply With Quote
Tags
rims, tires, toyo, winter
