Old 10-13-2012, 11:17 PM   #1
kadafi
Lots of DEWALT goodies + many other tools! Mostly brand new stuff! *UPDATED OFTEN*
Preferred method of contact anthony999@live.ca
Location - Mississauga
If you're buying under $100 worth, I will only meet in Mississauga. If you're buying over $100, I will meet at a reasonable distance.
Prices are firm but I will give you a deal if you buy multiple items.
**I'm open to trade for electronics only (phones/ipods etc.)**
1) DEWALT DWD525K 1/2-Inch VSR Mid-Handle Grip Hammerdrill Kit *BRAND NEW*
$150
Product Features
10.0 Amp motor delivers increased drilling performance
Patented DEWALT built motor design generates 50% more power with increased overload protection for added durability
Dual Mode: hammerdrill / drill for versatility in masonry, wood, or steel drilling applications
2-Speed range for high speed drilling or high torque applications
Mid-handle grip design with soft grip provides increased balance and comfort; Metal gear housing for jobsite durability and increased reliability
2) DEWALT 20V Max Li-Ion Compact Hammerdrill & Impact Combo Kit *BRAND NEW*
Model# DCK285C2
$250
Overview
NEW 20V Cordless MAX Compact Hammerdrill/impact Driver Combo Kit. The 20V MAX 1/2" Hammerdrill features two speed transmission (0-600 / 0-2000). The 20V MAX 1/4" Impact Driver features 3 LED lights with 20 second delay to provide visibility without shadows.
Compact, lightweight design fits into tight areas
Ergonomic handle delivers comfort and control
(2) Belt Hooks included for portability
Includes (2) 20V Max lithium ion 1.5 Ah battery packs
3) DEWALT 14.4-Volt Cordless 1/2 in. Compact Drill Kit *BRAND NEW*
Model # DC730KA
$140
PRODUCT DESCRIPTION
Experience compact power. This 14.4 Volt drill driver packs 300 uwo into a package that weighs only 4.3 lbs. With a heavy-duty frameless motor and 1/2 in. chuck, this drill is ideal for installers and contractors with a lot of overhead work.
Compact size: Allows users to fit into tight spaces
Lightweight design (4.3 lbs.) minimizes user fatigue
1/2 in. single sleeve ratcheting chuck reduces bit slippage
Dual speed range 0-400/0-1,450 rpm delivers optimal performance
High performance frameless motor delivers maximum power of 300 unit watts out
LED work light provides increased visibility in confined spaces
Includes: 1 hour charger, (2) 14.4 Volt batteries, screwdriver bit, heavy-duty kit box
Other batteries and chargers sold separately, this tool works with these batteries (DC9144, DC9091) and chargers (DCB103, DW9117, DC9310, DC9319, DC9320, DC012)
MFG Brand Name : DEWALT
MFG Model # : DC730KA
MFG Part # : DC730KA
4) DEWALT D25012K 7/8" Compact SDS Rotary Hammer Kit *BRAND NEW*
$130
Product Features
6 amp motor provides high performance and overload protection: (0-1,550 RPM, 0-4,150 BPM)
Variable speed trigger allows user to instantly control speed from 0 to dialed setting
Lightweight design for easy use and handling in a variety of orientations
Allows for usage in both rotary hammer and rotary only applications
Reversing feature helps release tool from bind up situations, and assists with removal of fasteners
Integral clutch reduces sudden, high torque reactions if bit jams
360 degree side handle adjusts easily for preference or use in tight spaces
Pistol grip design for preferred balance in multiple orientations
5) DEWALT DW5366 Anchor Drive Kit. 10 pcs. If you're buying any of the driller combo, i will sell it for $15, if you want just the anchor kit $25.
6) Dremel 754-04 4.8 cordless MiniMite Kit *BRAND NEW*
$40
Exact one as link http://www.sears.com/dremel-754-04-4...p-00930967000P
Product Features
Features include: Light duty cordless for precision
Removable battery pack lets you use additional packs for continuous use
5 Accessories
Small screw mandrel and sanding disc sanding disc
7) Skil 120v 1/2" Hammer Drill BRAND NEW IN BOX
$50
Skil 120V 1/2" Hammer Drill:
High torque 7.0-amp motor for demanding applications
1/2" heavy-duty chuck for drill-bit holding power
Sure-lock side-assist handle for improved safety and accuracy
2-finger variable speed trigger for increased control
Lock-on button for extended drilling
Soft-grip handle for added comfort
Model# 6445-02
8) Dremel 7300 MiniMite Cordless Rotary Tool *BRAND NEW*
$20
PRODUCT DESCRIPTION
The Dremel 4.8 Volt Cordless Rotary Tool is designed for drilling, sanding, shaping, detailing and other light-duty jobs, this compact, go-anywhere, use-anytime tool comes in extremely handy in and around the house. It can be used with any Dremel accessory bit with up to a 1/8 in. shank.
Two speeds 6,500 and 13,000 RPM to match the proper speed required
Compact and lightweight for easy handling
Two-year warranty
Includes: 4.8 Volt cordless rotary tool, 407 1/2 in. 60 grit sanding drum with mandrel, 401 mandrel, 414 felt polishing wheel, 432 1/2 in. 120 grit sanding band, 84922 silicon carbide grinding stone, and wrench
Includes tool only. Battery and charger sold separately
The Bosch difference - The most durable cordless tools in their class, 3 year provantage tool protection plan - The best tool service program available, 2 year battery life guarantee
Compatible with Dremel 756-01 Charger. Works with Dremel Battery 755-01
MFG Brand Name : Dremel
MFG Model # : 7300-N/8
MFG Part # : 7300-N/8
9) DEWALT D25300DH Dust Extraction System with HEPA Filter *BRAND NEW*
$140
The DeWalt D25300DH Dust Extraction System with HEPA Filter is to be used with DeWalt L-Shaped rotary hammer model numbers D25303, D25304, D25313 and D25314. The DeWalt D25300DH comes with a HEPA filter for the most extreme dust collection around. Features: 2-second power-off delay allows dust extraction to continue after drill is switched off HEPA filter delivers 95 percent efficiency at 0.3 microns Built-in motor keeps performance high while drilling Lightweight at only 3.3 pounds What's In The Box: DeWalt D25300DH Dust Extraction System with HEPA Filter L-Shaped Rotary Hammer NOT Included
kadafi is offline   Reply With Quote
Old 10-18-2012, 02:48 AM   #2
kadafi
Brand New in Box Driller/Driver $35
$35
PRODUCT DESCRIPTION
The BLACK & DECKER LDX112C-2 drill / driver are ideal for drilling and screw driving in various materials. Lithium-Ion power means it always ready to go, holding a charge for up to 18 months.
Lithium Ion battery always ready, holds a charge up to 18 months
By providing extra level of control, the 11 position clutch prevents stripping and overdriving screws
LED work light illuminates the surface for easier drilling in dark places
Soft grip handle provides added comfort during use
Ideal for drilling and screw driving through wood, metal, and plastic
MFG Brand Name : BLACK & DECKER
MFG Part # : LDX112C-2
Old 10-19-2012, 07:04 AM   #3
marek
Sent you a PM. Please respond.
marek is offline   Reply With Quote
