Old 10-01-2012, 12:40 PM   #1
325isdan
RWD wheels on FWD.
Wondering what issue will I run into with running RWD 14" on my Toyota Echo. Im looking at E30 4X100 ( medium offset?) and the echo takes high offset.
Will this be ok to run or do I need to run high offset wheels?
thanks
325isdan is offline   Reply With Quote
Old 10-01-2012, 12:57 PM   #2
the wheels will most likely sit flush with your fenders, it may actually look pretty cool.
Old 10-01-2012, 02:06 PM   #3
325isdan
I was reading about maybe running into tire wear issue or perhaps messing up the handling. Mind you the handling already sucks.
Old 10-01-2012, 04:13 PM   #4
If anything, handling should be better because of the more aggressive stance! Only possible issue might be tires rubbing on fenders, but I doubt it on a stock car.
Old 10-01-2012, 04:19 PM   #5
GeMc
GeMc's Avatar
You won't have any issue with a stock suspension. If it's dumped to the weeds, it might rub. I know people that track their Asian cars (MK2 Jetta & Hyundai Elantra) with E30 bottlecaps without issue. I'm sure your Echo will be okay.
German Mechanics
2530 Speers Rd #5
Oakville, ON Canada
(905) 286-4362
Mon-Fri 9am - 5pm
www.GermanMechanics.ca
GeMc is offline   Reply With Quote
Old 10-01-2012, 05:21 PM   #6
325isdan
Thanks everyone.
After researching more I found that;
Echo 40mm offset
E30 bottlecaps 35mm and I would assume the stock steelies run the same?
5 - 10mm max is no real issue for offset?
I plan on running 185/65/14 so just some tall skinny tires.
Old 10-02-2012, 10:14 AM   #7
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
You should be fine. Is the centerbore the same?
Stanceiseverything.com
Old 10-02-2012, 01:15 PM   #8
325isdan
Echo is 54mm
E30 is 56mm i belive.
Old 10-04-2012, 05:19 PM   #9
5style
Hatters gon Hatt
5style's Avatar
Get hubcentric rings, or you will get wheel wobble
