Old 08-29-2012, 07:45 PM   #1
e30sequel
QUAIFE ERR
feeler OBD1 swap 325TI m50tu body 300km
Ok folks, methinks at least some/most of the work was done at simplycars.
*the good*
its faster than you need it be
it sounds great at redline
stock engine swapped with 180km
driven 1 full year for less than 20k
short shift with suede boot
US M3 cluster with 114 miles
intake runs beside driver side fog light
ONE spot of rust bubble driver side rear
sunroof
LSD
m3 side mirrors
aftermarket headlights/brake lights
engine brace
f/r cross drilled rotors
lowered on HR springs
larger f/r sway bars
aftermarket sound
vin same on all panels
*information*
2 owners from new until the end of 2011
engine replaced at 285,000 with 3rd owner
new front suspension
comes with straight shitty 205 55 16 snows on replicas
*pictured Rims/Tires optional*
carfax available
*the bad*
interior shitty original with airbag light on and off
exhaust was 'made to work' and drones unless past 5k
abs light is on and off
the paint is cracked and crappy overall but ok from afar
The story is I want to sell this AS IS. If you take this on = most likely emissions related issues because it barely passed last round (after repeated failure of previous owner). Anyway, I think it will all be related to the exhaust and cat/o2 sensor, plus probably rebuilding calipers and SS brake lines and a regular tune up. If I do it I will ask for way more and will probably change my mind about selling.
ASKING $666,6.666 and I can understand how this may make you feel. Reasonable offers will be considered. If you are not buying please pipe in so we can chat....PM preferred. More information and pix to be added as we go.
Thank you.
Will post more pictures and videos later.
Steer with your QUAIFE
e30sequel is online now   Reply With Quote
Old 08-30-2012, 02:19 AM   #2
Wavy36Cabrio
whats with the tripple 6s
Wavy36Cabrio is offline   Reply With Quote
Old 08-30-2012, 09:52 AM   #3
e30sequel
QUAIFE ERR
To emphasize the EEEEEEEvil ness of the ti and all that drive it 'turning' ......
here is a sample test drive.....
and a once over of the body .....
lights.....(seems a few monkeys got together to install these ...
hint hint GO BACK TO STOCK with clear corners IMO)
Old 08-31-2012, 04:34 PM   #4
e30sequel
QUAIFE ERR
Ass shot!
we here should be aware of cost of bringing this car to its current configuration. there are expected issues as with any car ie maintenance.......
cost is reflective @ $6666 or reasonably close without the rims....
closer
pads/rotors new, ABS on/off dont know why and left pull when brakes applied at speed
I can fix everything to 100% for extra cost to buyer. thanks and more info to come as it happens.
the straight/balanced rims (with used snows) the car will come with......wait for it....
IF they were not oxidizing and peeling on every part of every wheel. look at what
YOU could turn these into if YOU put in some work or $$$$...dont take it 2 seriously
just having a little fun .......... enjoy
Old 09-04-2012, 06:13 PM   #5
e30sequel
QUAIFE ERR
I will now purify this deal by eliminating the excess 6's, so the CLOSEST to $6k will take it.
NEW PRICE (rims extra)
Dont be shy, pm your offer. I am reasonable.
TNX
Old 09-07-2012, 06:26 PM   #6
e30sequel
QUAIFE ERR
WEEKEND bump, for this weekend, due to some flakers......$6000 with pictured wheels and snows ....
this weekend only
come and drive it, bring cash, not stories
feel free to pm your reasonable offers
Old 09-08-2012, 09:14 AM   #7
e30sequel
QUAIFE ERR
Another drop to $5500...this weekend ONLY
All inclusive
Old 09-11-2012, 02:04 AM   #8
e30sequel
QUAIFE ERR
Back up .....as promised.....$6666 including all the wheels and safey /emissions negotiable
Pm what you think, thank you
Old 09-13-2012, 08:45 AM   #9
e30sequel
QUAIFE ERR
The car runs very nicely and the following items will be addressed (negotiable)
1 the exhaust will be replaced with an m3 one (modified) including the cat/o2
2 used leather sport seats / sport steering (rear seats remain as is)
3 tune up (spark plugs, filters, oils)
4 newer hood
ASKING $6500 and the above is negotiable
this is a VERY enjoyable set up and the car is worth way more if all the small things are addressed. This is the reason the price is lower considering the cost of bringing it to this stage. all major components are functioning as intented and the car is super tight......drivetrain and suspension feels/is new. Again, small issues which are part of regular maintenance are NEGOTIABLE so a very reasonable buy.....you will fall for the ti once you drive it even once......
pm and dont be shy
Old 09-19-2012, 08:00 PM   #10
e30sequel
QUAIFE ERR
best reasonable offer ......
Old 09-22-2012, 12:30 PM   #11
e30sequel
QUAIFE ERR
Wknd drop $5000 as is - firm
price to go back up after wknd
Old 09-26-2012, 08:47 PM   #12
e30sequel
QUAIFE ERR
Price bumpity biatch .... (dont bite pls)
$6600 plus tax with NO issues = emissions and safetied
1 hood replaced with better one
2 full tune and oils
3 full m3 exhaust fab w/ new o2
4 rebuilt calipers (seized, hence the pulling when braking)
Car is 100% tight otherwise - it drives/idles/pulls perfectly SO.........
OPTION #2
$5600 TAKE IT AS IS and do the work yourself
1 hood = less than $100
2 full tune = around $100
3 full used m3 exhaust $300 or less plus work/install about $200
4 rebuilt calipers or used m3 about $300
You will regret either not buying this car (about $6k) or not doing one up yourself ..................please ask your local specialist how much it will cost
If you do it up yourself, it will cost AT LEAST $6k = 318ti*a beater for $1k*, donor engine/parts, suspension, wheels/tires, sound/alarm, CLUSTER/ELECTRONICS AND ANY OTHER OUTSIDE LABOUR, and of course the TIME you invest etc etc etc ....
MAKES SENSE, NO ACCIDENTS, 95% correct m3 cluster, alarm, winters, shift kit, 18's with new (yes chinese!) rubber and used 16" alum snows, sunroof, fogs, angel eyes (yes chinese!) all black, ONE easliy corrected rust spot, WORK DONE LAST YEAR! ETC ETC .......
WILL ACTUALLY CONSIDER TRADES AS SOME HAVE COME MY WAY ........LET ME KNOW WHAT YOU HAVE OR BRING CASH
Old 09-30-2012, 10:01 AM   #13
e30sequel
QUAIFE ERR
$4500 final offer as is ........ Cash as is drive it home
final offer then back to the grind prices .....
Old 10-01-2012, 02:41 PM   #14
e30sequel
QUAIFE ERR
Price will be safety and emissions inclusive ......
$6500 or best reasonable offer .......
more pictures and information to come
Old 10-09-2012, 02:45 PM   #15
e30sequel
QUAIFE ERR
Now featuring leather manual sport seats ......
Price is negotiable ..... Let me know what you think is fair, PM your offers...
