Old 09-21-2012, 10:51 AM   #1
Fr0z3N
3 series not running right
323i pulled the codes yesterday and got
02 bank 1 out of control limit
02 bank 2 out of control limit
cyl 1 2 misfire
02 bank 1 something cant remember
02 bank 2 same as above
small fuel leak < 5mm
mass air flow
cleaned the maf and its running better but still not as before, pulled codes again today and got everything minus the maf code plus mis on 12346
any ideas as to what this can be? sounds like a sensor problem to me, could it still be the maf causing this
Fr0z3N is offline   Reply With Quote
Old 09-21-2012, 10:53 AM   #2
ScotcH
Well, the codes suggest it's the O2 sensors. SO maybe,I dunno, it's the O2 sensors?
Old 09-21-2012, 11:11 AM   #3
Fr0z3N
I forgot to add the brake booster has a vaccum leak too could that have anything to do with it? unseen air by the maf?
Old 09-21-2012, 02:17 PM   #4
Ceeker
fix by starting with the cheapest to the most costly. I'd take care of the vacuum leak then recheck codes. o2 sensors aren't uncommon.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
