Welcome to!
Old 09-14-2012, 01:46 PM   #1
what coolant to use on e30s
just wanted to know what to use
bimmere30 is offline   Reply With Quote
Old 09-14-2012, 08:37 PM   #2
164.3ci Of Fury
karmatose's Avatar
I use the BMW branded stuff from the dealer. One jug does 8L which is just about enough to do a full flush, fill and bleed.
I'm sure there's less expensive options, but much like what you're probably seeing now I saw no consensus on what to use. So I went with what I knew wouldn't leave me at the side of the road.
Old 09-15-2012, 02:24 AM   #3
black and blue
davericher20's Avatar
I run pure distilled water in the spring/fall/summer months,then i use a 50/50 mixture of bmw coolant/distilled water in the winter
Old 09-15-2012, 07:51 AM   #4
The regular Prestone stuff from Crappy Tire works fine.
Old 09-15-2012, 08:05 AM   #5
It's an e30 you can piss in it and it won't make a difference.
Just be sure to bleed it and change it regularly.
Old 09-17-2012, 07:36 AM   #6
I also use the bmw stuff, but I'm sure it's unnecessary.
