09-12-2012, 01:22 AM
#1
DIYer
Car: e30 325is '90 300k!
Help, my fuel pump died!
As title says, I went to get my hair cut this morning and when I started my car before leaving the parking I noticed that the motor wasnt running as usual.
I tried to rev it up but it it only went to 2000 rpm, so I turned around in the parking lot and parked where it died and did not restart. As I had some problems before with my fuel regulator, I had a permanent pressure gauge installed on my line, and it was barely doing 10psi... and I don't hear the pump prime anymore. Weird part is that it was running perfect on the way there.
I'll try to change it with an older pump assembly I had but I might need a whole assembly as my electrical connections seemed weak!
So if anyone has an fuel pump assembly for a e30 325is 1990, please let me know!
On a unrelated note: my brother just bought a car and needs an inspection for his insurance (because its "modified"). Any places around Ottawa-Gatineau??
Thank you!
09-12-2012, 01:43 AM
#2
Car: 330ci SC, M5 Touring
I wouldnt call it "weird", when it comes to fuel pumps they work fine until they just stop!
Very rare to see some symptoms before...
09-12-2012, 08:11 AM
#3
DIYer
I had problems with my first e30 with the fuel pump, it would run just fine at before hitting 60km/h or 4000 rpm and would not feed enough gas to support the demand.
Anyway, I'm checking the car tonight, so in case ; any fuel pumps around ottawa, any1?
09-12-2012, 09:00 AM
#4
Car: many
I got one if you want.
i'm in Rockland ontario, but work in Ottawa at the Mint right next to the bridge to Gatineau:-)
it's used from my 1990 325ic, I replaced it with a walbro 255 as I'm going turbo
yours if you want it, $50.
09-15-2012, 09:58 PM
#5
DIYer
Fixed,
I ended up putting a fuel pump from an e36 320i, the pressure is slightly higher (5psi) and now the motor seems to be working even better.
Thx anyway
09-16-2012, 12:39 AM
#6
Car: many
No problem  glad it worked out 4 u!
09-16-2012, 08:20 PM
#7
Car: '93 320i
Happened to me a month ago, but I got stuck in Rigaud... 2 hrs from home -_- The worst part is that I just changed the pump because the last one was doing a weird squeal AND the other guy in the car had to catch a flight. A good friend of mine finally brought my old pump to me and we changed it in a restaurant parking lot. Ahhh what a day !
09-17-2012, 08:06 AM
#8
Car: many
That's my moto with my BMW aswell. Fix it till its broken lol
