Old 09-06-2012, 09:23 PM   #1
E46coupe
E92 M3
E46coupe's Avatar
looking to install headers in the M3 any reccomendations?
anyone with any reputable shops? I also want to pass emissions is this possible?
Space Grey,Fox Red,DCT,EDC,Swift Springs,Carbon Fiber Roof,Diffuser,Splitters,Carbon Mirrors,M Performance Exhaust,ZCP Wheels,Caron Fiber Roof,15/12.5 spacers
E46coupe is offline   Reply With Quote
Old 09-07-2012, 10:12 AM   #2
toy4to
Any of the forum sponsors here can install headers. RMP, StanceFactory, Bimmersport, etc. Expect labor to be in the neighborhood of $4-500. While you have the headers out, definitely replace your CPV o-ring.
If you are running catless, it'll be damn tough to pass emissions. So, get yourself a catted section 1 and you'll be fine with passing emissions. I see that you have a rasp pipe...either get cats welded into that, or sell it for a different setup with cats.
toy4to is offline   Reply With Quote
Old 09-07-2012, 02:56 PM   #3
E46coupe
E92 M3
E46coupe's Avatar
ok bro thanks for the reply!!!! I will look into my options
will there be a noticeable gain 15h.p or so?
Old 09-07-2012, 05:20 PM   #4
RMPMOTORS
RMPMOTORS's Avatar
We have installed many sets of headers, the gains are decent.
We also can dyno your car before and after to confirm the gains in hp!
www.RMPMOTORS.com
www.Facebook.com/RMPMotors
Old 09-07-2012, 08:28 PM   #5
doogee
doogee's Avatar
You more than likely wont pass emissions. You'll need some cats in the mid section.
Do not go to Bimmersport. RMP and Stancefactory are good options.
Dakar M3 Track Build Thread
Old 09-09-2012, 12:52 PM   #6
Maple
If you plan to pass emissions AND have a nice clean install that will last and be reliable then your best bet will be to get CSL manifolds and section 2.
Other options consist of poorly made china parts that will fall apart after a year.
It'll set you back about $1700-2000 plus about $500-700 for install.
You will gain 11rwhp at upper RPM range, have a much nicer , raspier exhaust tone. Your wallet will also drain about $2500 but your E status will go thought the roof.
If you need help with getting OEM CSL manifolds, let me know
Maple is offline   Reply With Quote
Old 09-09-2012, 11:32 PM   #7
E46coupe
E92 M3
E46coupe's Avatar
so your saying I may not pass emissions with the csl setup?
Old 09-09-2012, 11:32 PM   #8
doogee
doogee's Avatar
CSl setup will work. Good luck finding that midpipe though.
Old 09-09-2012, 11:35 PM   #9
toy4to
You'll pass with oem csl/euro setup no sweat. It's only when you're going catless that will cause issues.
Old 09-10-2012, 08:13 PM   #10
Maple
huh ?
I said that you WILL pass emissions and that its the ONLY safe/reliable method of doing this.
How could you;ve gotten something else from my post
Old 09-10-2012, 08:27 PM   #11
E46coupe
E92 M3
E46coupe's Avatar
Ok I just Hear from different forums that the csl option will not pass emissions so I need to find these parts and try it out
Old 09-11-2012, 10:20 AM   #12
toy4to
CSL setup WILL pass. Hell, I am running CSL headers with catted section 1 AND a supercharger and I still passed my emissions test in 2011.
Old 09-11-2012, 10:59 AM   #13
ac_2007
Cruising in Top Gear
ac_2007's Avatar
A 325 running catless headers gained 11whp.
Expect more if going catless, or around the same if they're just high-flowing.
Old 09-11-2012, 03:17 PM   #14
E46coupe
E92 M3
E46coupe's Avatar
are the euro headers the same set up as csl's I know there is a weight difference. Its a little cheaper then csl parts.
