Old 09-06-2012, 01:23 PM   #1
Mlatter
drive shaft question
Dose anyone know if I drive shaft from a 91 318is standard will fit on a 87 325e standard? I need a drive shaft BAD an this one is a good deal.
Mlatter is offline   Reply With Quote
Old 09-06-2012, 01:53 PM   #2
No. As far as I know, the 325e driveshaft is shorter than the other shafts.
Old 09-06-2012, 04:02 PM   #3
InfiniteDice
14 Years with the E30
InfiniteDice's Avatar
Depends if it's a 325e auto or manual shaft.
Look on the etk. or just go to realoem and check the lengths.
Old 09-06-2012, 04:14 PM   #4
Ceeker
best to compare part numbers on realoem,com
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 09-06-2012, 05:00 PM   #5
It won't fit...
Old 09-07-2012, 01:57 PM   #6
frankie591
e driveshafts use the big guibo, so no it will not fit
Old 09-07-2012, 02:08 PM   #7
The guibo is common between all E30 models.
Old 09-07-2012, 02:12 PM   #8
frankie591
The '87 325e came with a 135mm guibo vs the standard 110 for the rest of the e30's. People like those e driveshafts because they have the proper sized guibo to play with an m30 swap and transmission.
Old 09-07-2012, 02:18 PM   #9
It appears they changed over in '86. My 325e is an '84 which explains why it has the 110.
Good call.
Old 09-07-2012, 02:22 PM   #10
frankie591
Good call.
Funny how they changed to a big guibo cause of the torque boost the e had over the i, however guys with ls1 swaps run the 110mm guibo with no problems. I guess thats the famous bmw engineering
Old 09-07-2012, 02:25 PM   #11
It's because they knew people would probably end up boosting the shit out of them lol
Old 09-07-2012, 02:47 PM   #12
InfiniteDice
Use the front half of the 318 and the back half of the other? The diff flange is probably swappable. I don't know enough about 318 mechanicals to comment really just throwing the idea out there.
Old 09-07-2012, 07:40 PM   #13
karmatose
164.3ci Of Fury
karmatose's Avatar
86, 87 325e and the M3 use the large guibo. I also have the large guibo in my 325is (and the Revshift "flex" disc, but that's fairly irrelevant). I had to find one of these not long ago and it took a bit of doing.
Old 09-08-2012, 01:46 PM   #14
Roysneon
Roysneon's Avatar
The 318 and 325 driveshafts are different lengths, guibo sizes aside. One half of the driveshaft is the same size between the two, the other isn't, I forget which one though.
Old 09-08-2012, 05:35 PM   #15
e30_kid89
The Afro-stig
e30_kid89's Avatar
It's usually the rear half that are the same lengths.
