Old 08-28-2012, 01:00 AM   #1
doogee
doogee's Avatar
E36 M3 Racecar
I have a 1997 M3 Trackcar for sale. I have documentation of the entire build. Car is in great shape and ready for racing. I have some spare parts that will go with the car as well. All parts on the car are in like new condition. No money was spared.
This car doesn't need much to make it a very competitive IP car. Can run at the top of GT4 in CASC or with a few small mods, run it in GT3.
The car has done a 1:35.4 at Mosport.
Looking for $20,000 obo
Engine and Drivetrain:
S52 3.2 OBD1
M50 Intake Manifold
413 ECU with TRM Tune
S54 Oil Filter Housing
Oil Cooler with Stainless Braided Lines
Aluminum Radiator
SPAL 16” Cooling Fan
Euro Expansion Tank
3.73 LSD
JB Racing Flywheel (9 lbs)
E46 M3 Front Exhaust section
Rogue Engineering X-Pipe Rear Section
Euro Supersprint Replica Headers
Solid Engine and Transmission Mounts (Front Subframe is reinforced)
Stewart High Performance Waterpump
Dual Fuel Pump System
Suspension and Brakes:
TcKline Double Adjustable Coilovers 500/700# (Rebuilt Winter 2011)
Ground Control Race Camber Plates
Ground Control Swaybar Endlinks
Solid Rear Subframe Mounts
AKG Rear Lower Control Arms
Turner Motorsport Upper Control Arm Bearings
Solid Diff Mounts
Turner Motorsport Trailing Arm Bearings
Bimmerworld Delrin Front Control Arm Mounts
Bimmerworld Stainless Brake Lines
Euro M3 Floating Rotors
Ground Control Spherical Race Rear Shock Mounts
Custom Brake ducts with Backing Plates
OEM X-Brace
Interior:
VDO Gauges (Oil Temp, Oil Pressure, Coolant Temp)
6 Point Cage
Bimmerworld Race Shifter
VAC Seat Mounts L+R Side
Small Fire Extinguisher
Wink 5-Panel Rearview Mirror
Delrin Bushing Replacement for Brake and Clutch Pedals
Suede Sparco Steering Wheel
Rogue Engineering Steering Wheel Quick Release
Sparco 6 Pt Harness (EXP 2014)
Body:
Carbon Fiber Hood
LTW Highrise Spoiler
Wheels:
Bimmerworld 75mm Wheel Studs
Kosei K1 17x8.5”
Koni Challenge Hoosiers (225/45/17)
Dakar M3 Track Build Thread
Old 11-09-2012, 03:39 PM   #2
BMWNTHZST
BMWNTHZST's Avatar
Is your car still for sale? I'm very interested in your car.
PM sent
2015 F80 /// M3 Alpine White / Black
2011 E93 /// M3 Metallic Space Grey / Fuchsrot
1997 E31 840Ci Jet Black / Black
2004 E46 /// M3 Laguna Seca Blue / Black
BMWNTHZST is offline   Reply With Quote
Old 11-09-2012, 10:36 PM   #3
doogee
doogee's Avatar
PM sent
Just sent you an email!
Latest laptime at Mosport is a 1:34.9
Old 11-18-2012, 12:56 PM   #4
doogee
doogee's Avatar
Sold.
Old 11-18-2012, 06:28 PM   #5
BMWNTHZST
BMWNTHZST's Avatar
I'm glad to hear you found a buyer
