Old 08-15-2012, 01:07 AM   #1
e30sequel
QUAIFE ERR
trick to it? help appreciated
although rear subframe swap kosher, is it possible to swap 318ti front end (6 cylinder weight appropriate coilover/BBK/control arm everything necessary) over to e30?
please explain how this can be done, in detail please. I am stuck with this shit otherwise and they are pretty new.....any help/trick/detail/pix MUCH appreciated .......
Steer with your QUAIFE
e30sequel is offline   Reply With Quote
Old 08-15-2012, 02:27 AM   #2
There is no such thing as 6 cyl appropriate 318ti!!!
It can be done if you use the full spindle, but special bushing is needed, or the wheel will sit too far back
Old 08-15-2012, 06:47 AM   #3
BMe30
all by chance...
BMe30's Avatar
Correct me if im wrong but wasnt there a 6cyl ti offered in the states? Unless he found a ti that had a 6cyl swap.
I can only assume that you are doing a 5 bolt swap... Google it.. Youll find some good info on rev3 and e30tech
From what i remember you use the e36 struts, e30 strut mounts, e30m3 offset cab, post 97e36m3 control arms.
But id double check that...
Gone but not forgotten
Old 08-15-2012, 10:19 AM   #4
cormier
cormier's Avatar
You can't sell your ti stuff and get proper e30 stuff?
Old 08-15-2012, 04:05 PM   #5
e30sequel
QUAIFE ERR
TI was swapped w iron block vanos 2.5 then done w appropriate coil overs ...
was available as 323ti in europe from 97-2000 which = 97-early 98 are good for importing as of now (battery moved to proper right rear) and newer alum block b25 employed ....
Thanx for the guidance .... Doing a part out so didn't see point of selling and getting another new set up when I could make this work
Old 08-19-2012, 12:16 AM   #6
e30sequel
QUAIFE ERR
cormier, your suggestion seems like the right one ..... I think I will pursue that route
anyone have an idea of what a swapped 318ti would fetch about 200 on body and 250 on engine - but all working and properly done???
Old 08-19-2012, 10:21 AM   #7
cormier
cormier's Avatar
E36s are drastically down in value now -- most people I see selling them don't get asking or sold in timely manner.
It really depends on condition and what makes it stand out from the rest -- that said there is a following for the tis
Your plan is for a swapped e30?
Old 08-19-2012, 10:29 AM   #8
e30sequel
QUAIFE ERR
Yes several swaps, aiming for one with s52 and other more period correct 3.4 from e34.....was researching rebuilding one being sold by axxe with the e28 tranny ......not sure yet as I want to get into the bottom end in the rebuild and do far the price is not very cute for a the stuff required for a thorough rebuild ...
Old 08-20-2012, 08:22 PM   #9
Roysneon
Roysneon's Avatar
Stock E36ti has non vented front rotors and the wheels will sit far too far back in the wheelwell.
E36M3 front knuckles and control arms will sit the wheel near teh proper specs, especially with caster gaining control arm bushings such as the stock e30M3 bushings or Treehouse racing delrin ones.
Basically, E36 non-M does not fit, is not an upgrade and will make you hate driving the car. The E36 compact rear end will bolt right up, however, then you're half way there.
Old 08-21-2012, 01:40 AM   #10
e30sequel
QUAIFE ERR
Guys selling complete m3 e30 f/r susp ....$1400 wow....
Wanna have a look.
Old 08-21-2012, 02:34 AM   #11
After mid 98 the Ti came with vented rotors, like the rest of the E36's!
Old 08-21-2012, 06:26 AM   #12
e30sequel
QUAIFE ERR
Euro, a favor in lieu of the $500 you owe me (that u publicly declared, and for which I have the proof of purchase), some advice please..... what do you think this ti, with drilled and vented rotors would go for....I'm torn between parting and cleaning it up and putting it up for sale.....so your expert advice needed, again in exchange for this consulting, I will forego the $500 crispy bills ....lol
The ti utterly WAILS at 7k....too intoxicating to be taken apart bug $$ talks I guess
Old 08-21-2012, 09:39 AM   #13
supernaught
supernaught's Avatar
if you want a 5bolt swap for an e30, there is a guy local to me selling a setup with e36m3 front end and 318ti rear... cheaper than the e30m3 stuff with much bigger front brakes.
Old 08-21-2012, 10:05 AM   #14
e30sequel
QUAIFE ERR
No that's y I bought the ti, but now I completely changed mind about 5 bolt.....unless from e30 m3....if I could get that package for 1k it would be ok methinks ....
