Old 08-16-2012, 11:52 AM   #16
Mlatter
ok so i pulled the starter and yes it was a jammed solenoid. i also cleaned up all the contacts just for good measure! but once i got it all back together and went to start it, it just cranked n cranked and wouldn't turn over. i smelled gas when i opened up the intake so the pump is fine, maybe i fowled the plugs? (it got dark by then so i had to pack it up) im going to pull some plugs after work, maybe check to see if i forgot to plug something back in. also there are @ plugs that look the same that come off the tranny but one is white n one black, i think i mixed them up. is there any way to know which is for what?
Mlatter is offline   Reply With Quote
Old 08-16-2012, 12:18 PM   #17
E36is
'OldSchool..'
E36is's Avatar
crank position sensor?
Old 08-16-2012, 01:36 PM   #18
The early model E30s running motronic 1.0 had the crank position sensors in the bell housing. If you mixed those wires up you won't be getting a crank signal.
Old 08-16-2012, 01:58 PM   #19
Mlatter
OoOooooooOoOOooh!
durp!
