Old 08-13-2012, 04:39 PM   #1
Mlatter
e30 wont start :(
so here we go.....
turn the key and all the normal lights turn on and can hear the fuel pump run but no start?
so i checked:
-fuses
-battery
-50amp fuse
-starter and alternator wires
-wires/connections under the dash
so then I:
-charge the battery over night. still nothing.
-boosted the battery. still nothing.
-consulted the internet
and its said:
-starter relay?
-ignition signal wire?
-grounding wires?
-gremlims?
dose anyone have any insight or encountered a problem like this before?
Mlatter is offline   Reply With Quote
Old 08-13-2012, 05:55 PM   #2
cormier
cormier's Avatar
Sorry to be clear - no cranking?
Old 08-13-2012, 06:49 PM   #3
Mlatter
Yes sorry no cranking
Old 08-13-2012, 08:04 PM   #4
E36is
'OldSchool..'
E36is's Avatar
check engine ground straps, may need cleaning.
Old 08-13-2012, 08:24 PM   #5
Clicking?
Old 08-13-2012, 08:56 PM   #6
Ceeker
^ as they said..check for bad ground. usually most common is the oil pan to the drivers frame rail. they all corrode.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 08-14-2012, 07:09 PM   #7
Mlatter
grounding strap cleaned an reinstalled. no start.
no clicking. just normal dash lights n the sound of the fuel pump humm.
Old 08-14-2012, 07:15 PM   #8
You could always pull the starter and bench test it.
Old 08-14-2012, 07:23 PM   #9
Mlatter
i was just look at that. looks like a pain to take out.
Old 08-14-2012, 08:18 PM   #10
It's a bit of a pain, but once you figure it out, it can be done in an hour.
Old 08-14-2012, 08:19 PM   #11
E36is
'OldSchool..'
E36is's Avatar
+1 on starter, could be a jammed solenoid.
Old 08-14-2012, 08:47 PM   #12
Mlatter
haha^^ just found something on e30tech saying that too.
actually doesn't look that bad now i've see a dyi. but i guess its gonna have to wait till tomorrow, its sitting in a parking lot at work.
Old 08-14-2012, 09:24 PM   #13
Roysneon
Roysneon's Avatar
I would start checking for voltage at one end or the other. Either the starter and work toward the battery, then to the ignition switch or the ignition to the starter. Find out where the power stops being distributed and there's your problem.
But I'm terrible with electrical work.
Old 08-14-2012, 09:50 PM   #14
DIRT_Racer
DIRT_Racer's Avatar
silly quesstion, is it a standard or automatic?? I am thinking clutch or Park Nuetral safety switch.
use a volt meter on the starter SMALL terminal, check for 12v when the key is turned to start, if it lights up, pull the starter and bench test, if it doesnt, then look back as to why the starter isnt getting a signal
See the #90 DIRT 318i @ www.facebook.com/brewstermotorsports
DIRT is for racing, Pavement is for getting there. The only way to turn left, is to turn the wheel RIGHT!!
Locked Your DIff and hate it?
Give me a shout, will buy em up cheap, DIRT tracks are the ONLY place for a welded diff!!
DIRT_Racer is offline   Reply With Quote
Old 08-14-2012, 09:57 PM   #15
E36is
'OldSchool..'
E36is's Avatar
^^ lol, i completely forgot about that neutral switch and my eta has that problem! If your car is a automatic like my eta, i either put the selector in neutral, or i lightly put sideways pressure on the selector while starting the car. 99.99% this will always start the car.
