Old 08-08-2012, 06:42 PM   #1
MikeDsantos
E30 engine swap with M3 s52
Wanted to know what would you need besides the engine itself, tranny, clutch wiring harness, and subframe what else do you need and where can i get a custom made subframe? any links? Also would it be just as easy as putting in an s54?
Thanks!
MikeDsantos is offline   Reply With Quote
Old 08-08-2012, 07:40 PM   #2
Quack
Wheelman
Quack's Avatar
you should really talk to Stance Factory about this, especially if you want an S54, or PM Mystikal or Zimmie on the board, they run Stance Factory.
Stance Factory Inc.
695 Finley Ave Unit 2
Ajax, Ontario L1S 3T1
Phone: 647-889-9554
E-mail: info@stancefactory.com
Regular Hours: M-F 11am-7pm (by appointment only, please call ahead)
here's some recent work they have done http://www.maxbimmer.com/forums/showthread.php?t=151601
Old 08-08-2012, 08:50 PM   #3
cormier
cormier's Avatar
You can keep your subframe. S52 is more documented and easier than s54. Do some reading on 24v swap section (all the stickies at least) on r3vlimited.com and/or e30tech. Again, there's LOADS documented on the m/s5x swap that can give you a complete parts list and much more.
If you're looking for s54, keep in mind theres also other swaps that can do the same power cheaper. +1 on stance factory they do a ton of theses was very well.
Old 08-09-2012, 08:28 AM   #4
marek
I know someone that has all the necessary parts for the swap. Oil pan, booster, etc.
marek is offline   Reply With Quote
