Old 10-18-2012, 12:13 AM   #1
Nguyen_E30
0011 0001 1000
Soft Clutch
Need some help here.
Not sure what's wrong but my clutch has gone really soft all of a sudden. Like when you press down it's slow on the return. I'm thinking its the clutch master or slave cylinder. The car still goes into gear with no grinds.
Any input would be helpful.
Thank You!
Nguyen_E30 is offline   Reply With Quote
Old 10-18-2012, 10:24 AM   #2
iverson03tj
iverson03tj's Avatar
check ur fluid level? maybe a leak?
PREVIOUS CARS
Old 10-18-2012, 04:48 PM   #3
SamE30e
SamE30e's Avatar
Check fluid level first, if it's gone below the point of the hose for the clutch master, you need to find out why, top up and bleed.
If it's fine, find the leak.
Is your driver side floor wet?
85 325 - Turbo M52B28.
