Old 07-28-2012, 07:57 PM   #1
rwdbmwm3
05 325ci - how to find engine code
I got a customer that wants me to check if his engine is original
Where can I find the engine code and what is the oem engine for 05 325ci automatic
rwdbmwm3 is offline   Reply With Quote
Old 07-28-2012, 08:41 PM   #2
blakneto
blakneto's Avatar
Do you mean, the customer wants to know if the engine was swapped?
Wouldn't the VIN be etched on parts of the engine block?
blakneto is online now   Reply With Quote
Old 07-28-2012, 10:29 PM   #3
Eurostyle
Eurostyle's Avatar
^^^no, only a sticker at the back, that falls off or becomes unreadable in time. E46 motors are horrible for identification, it could be a 323 in a 330 and you would never know.
Eurostyle is offline   Reply With Quote
Old 07-30-2012, 06:55 PM   #4
rwdbmwm3
Can I get pic of sticker and possibly location?
Maybe I'm lucky and it's still there
Old 08-01-2012, 10:10 AM   #5
ac_2007
Cruising in Top Gear
ac_2007's Avatar
Scanning the DME and comparing software versions will usually tell you. Nevermind that it pretty much identifies itself as an M54Bxx
ac_2007 is online now   Reply With Quote
Old 09-03-2012, 09:31 AM   #6
Maple
Sure you'd know. Ms42 vs Ms43, DBC vs DBW, TB size and so on.
Back to OP, if you drive that car to my house , I'll tell you which engine and which trans it has and whether its original or came from india within 10 minutes. Im not prepared to give such information for free.
Maple is offline   Reply With Quote
Old 09-03-2012, 11:23 AM   #7
Eurostyle
Eurostyle's Avatar
And all of those are things that will get swapped between motors, so at the end it will look 100% the same! Trust me I have looked at both motors fully stripped side by side, and they even have the same part #s!
Old 09-03-2012, 02:03 PM   #8
Maple
Well , I've seen both stripped as well and I think if one were to go through the hassle of swapping everything from a B30 onto a TUB25 just to hide the fact that it was a TUB25, Id give him a medal or carve a sculpture in him name . BUt I'd still be able to tell what it really is
Sure the blocks are the same(the blocks are the same thought the whole E46 family apart from S54) but you can tell a different between engines even if you;re stripped down(well , as long as they're not stripped down to a bare block, lol), all you need is experience.
Its not that hard , really isnt
Old 09-03-2012, 03:10 PM   #9
Eurostyle
Eurostyle's Avatar
Actually it is, as they are the same, its the pistons/cranck/rods/camshafts that make the engine what it is. Sooo a 325/328/330 head casting will be the same for all models...no matter what...With the exception of the 320, that is specific. Do some research with the parts numbers, you would be surprised how much you can find out!
Old 09-03-2012, 03:14 PM   #10
Eurostyle
Eurostyle's Avatar
$$$$ can make people do a lot of things, seen it more then once. If they can buy a 325 engine for $500, and not spend $2000 for the propler 3.0, they will do it. Just to sell the car to unsuspected buyers.
Old 09-03-2012, 04:11 PM   #11
Blackedout95
Me no thinks Maple knows who Phils is.
E46
Old 09-03-2012, 04:33 PM   #12
Maple
I know all of that and some more, no need for research . But thank you anyway.
I've only seen people try to make a TUB look like a B30 motor, and they could've fooled a noob with it, but they couldnt fool me.
Like I said , there are ways to tell the difference between a TUB25 and a B25/B30, even if the engine is stripped down. Even if there is no valve cover and all you have is a block and the head, there are ways to tell the difference. And in the case of OP, its a matter of 2 minutes and then add another 8 minutes to tell when it was built and if it was in fact original.
Old 09-03-2012, 04:34 PM   #13
Maple
Me thinks Phillip dont know me . I know very well who he is .
Old 09-03-2012, 04:39 PM   #14
Eurostyle
Eurostyle's Avatar
Can you post some of those differences so we can all learn something!?
Old 09-03-2012, 06:34 PM   #15
Maple
There are a tonne of differences between TUB25 and a B25/B30. Some , I already mentioned previously , others are injectors, fuel rail, and many many other various small pieces. You can determine by looking at those(you'd have to know what you;re looking for first). If one were to have a TUB25 with a swapped B30 intake manifold and all its components, B30 cats, B30 sensors , MAF and Intake .... You can still find out that its a TUB25 simply by looking up the OBD Values . INpa is a very good software to do so. Obviously you;d have to know what to compare them to otherwise you'd be looking at a bunch of numbers not knowing whats going on. Look at Vanos values, lambda , camshaft and general adaptations. You cant hide nothing, a TUB25 wont run the way it should(proper) with B30 injection system and B30 intake mani. Ms43 ECU might not like(not 100% sure) some of the Ms42 specific sensors and if thats the case, INPA will tell you all that
BUT , if you said someone had stripped one down, meaning no intake mani , no exhaust mani , no crank damper, and all you have is a block with the head attached to it all you need to do is look at the in take cam . B30 has a specific B30 intake cam , all others ,320,323,325,328 share same intake cams . ONly look at the intake cam as exhaust cams are shared thought the whole E46 6 cyl engines apart from M3 and ZHP .
And if one were to go as far as swapping the cams too, well then only thing left is to bust open the head and check the piston clearance , or if you want a quick check then take out your most powerful flash light and look down the spark plug hole after you take the plug out and look at the piston top. B30 has a Unique piston top that sets it apart from TUB25/28 and B22/25 .
You CAN tell the difference , you just need to know what to look for and be prepared to look further.
Now, if the owner changed ALL of that just to hide the TUB ,then I would carve a statue in his name out of solid marble and display it at my friends next gallery.
