Old 07-17-2012, 07:57 PM   #1
ihearte30s
ihearte30s's Avatar
ETA 2.8 Stroker NA Combos??
Hey guys so I'm putting together a 2.8 eta and wanna go all motor. I was wondering what kind of combinations i could use, right now i have an m20b25, m20b27 and an m52b28. I'll be using the crank from the m52 but was wondering what piston and rod combo to use to get the best compression. I just want to see if there are any stock pistons i could use, before goin out and getting a custom set. I've read a couple threads on some forums claiming they were able to get 12:1 with the m52 crank, ETA rods and M52 pistons that were skimmed down hopefully there's a bit more info on this.
Anyways even if you guys want to just post up the combinations you've put together that'd be great!
ihearte30s is offline   Reply With Quote
Tags
2.8 stroker, eta stroker, stroker
