Old 07-11-2012, 03:49 PM   #1
Syn
Arrow Work Wheels for my E39 (Please Help)
Work VS wheels
Front is 19x9.0 and rear are 19x10. Tires size in the front is 225/35/19 and for rear is 275/30/19
will these fit my 2003 540i? and if not can I make them work with spacers?
Thank you.
Syn is offline   Reply With Quote
Old 07-12-2012, 01:17 PM   #2
Need to know offset. Width and sizing seems fine.
Old 07-12-2012, 03:08 PM   #3
Quack
Wheelman
Quack's Avatar
pretty narrow tires on the fronts, should be 245/35/19, the rears tire size is correct.
but like mentioned above, need to know rim offset to know if it's going to fit or not.
Old 07-12-2012, 08:43 PM   #4
Syn
Offset is +26 in the front and +25 in the back
seller says its "hub centric so it will fit all bmw" for center bore measurement.
Does this help?
thanks again guys
Old 07-12-2012, 11:30 PM   #5
Does this help?
thanks again guys
The E39 has a bigger center bore then all other BMW's, so most likely not. But it can always be machined to make it fit.
Old 07-13-2012, 10:55 AM   #6
Syn
