Old 07-09-2012, 01:59 PM   #1
Clutch Alignment tool (KW area)
I'm going to be needing a clutch alignment tool to install my new clutch. Does anyone in the KW area have one that I can borrow?
And no, I'm not going to just "line it up by eye"
Old 07-09-2012, 07:46 PM   #2
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
I have one in Mississauga somewhere. When do you need it?
Old 07-09-2012, 11:17 PM   #3
This weekend.
Old 07-10-2012, 12:16 AM   #4
E30M42cab
Parts Hoarding Specialist
E30M42cab's Avatar
I've got one... text me if you want to borrow it. Grab it in Milton.
Grow up and move on.
Old 07-10-2012, 12:12 PM   #5
cormier
cormier's Avatar
:o I thought the eye -line up was the golden standard!
I have one in the south east KW area that I'll hopefully be done with by Sunday, pm if need be!
Old 07-10-2012, 12:28 PM   #6
^ If Scott can't find his I'll be giving you a shout. Thanks.
Old 07-10-2012, 05:58 PM   #7
E30M42cab
E30M42cab's Avatar
The input shaft is my alignment tool. Poke it in, wiggle it around, give it a push. Done. Then take her out for dinner.
Old 07-10-2012, 07:12 PM   #8
InfiniteDice
14 Years with the E30
InfiniteDice's Avatar
+1 for trans input shaft.
Old 07-10-2012, 10:33 PM   #9
frankie591
I can bring mine to the meet this thursday if you still need one
Old 07-10-2012, 11:47 PM   #10
E30M42cab
E30M42cab's Avatar
K, found mine, I left it in my mail box and I'll text you directions. If you want to use Frank's or Brian's that's fine too. Really, if the engine is out, and the tranny is out, just eyeballing it and using the input shaft works fine. Once you align it with the tool, it all gets fubar'd once you start fiddling around with the input shaft and tranny... it's right back out of alignment once you touch the shaft on the clutch plate and bang it off the bearing a couple of times. Be a man Steve. No tool. 'Brute force and ignorance' is what I always say!
Old 07-11-2012, 08:51 AM   #11
The only reason I wanted the tool was because I haven't changed a clutch yet so I don't know what to expect. If it's really that simple then that's sweet. I'll still grab Frank's at the meet just for good measure. Thanks anyway Scott
If you could that'd be great.
Thanks.
