Old 07-09-2012, 10:04 AM   #16
ScotcH
3.73 all the way if you're choosing an all around ratio.
Old 07-09-2012, 10:13 AM   #17
sb_600
sb_600's Avatar
Originally Posted by doogee View Post
Tires are 225/40/17 Hoosiers.
Better driving + shorter tires must be the difference... I run 245-255/40R17s
It'll be fun to compare on Thursday
Shawn
sb_600 is online now   Reply With Quote
Old 07-09-2012, 10:27 AM   #18
Oh SNAP! lol!!
Old 07-09-2012, 10:28 AM   #19
sb_600
sb_600's Avatar
LOL I meant better driving on Kurt's part, I still have a lot to learn
Shawn
Old 07-09-2012, 10:33 AM   #20
Nolimit77
re
Well, I think I have my answer based on this past weekends OTA event at TMP. If I were to switch to the 3.91, I would have to shift into fourth through the short shoot before the chicane which would not be ideal. Good thing I didn't make the move on the diff before the weekend. I was however able to remove my fan clutch, AUX fan and A/C before the weekend and I bettered my PB by a few tenths. Now sitting at a 1:23.3 In the next couple weeks I will most likely try out a 3.38 LSD and see if there is an improvement along with the M50 manifold swap.
Anyone else here have times from TMP?
Nolimit77 is offline   Reply With Quote
Old 07-09-2012, 10:50 AM   #21
Haha you sure?
Anyways, those tires he runs are about the same as yours no? They are the 225/45 Hoosiers... same as the Contis. They have about the same diameter as the 245 Contis, give or take a 1/4"
I've also done a 1.23.3 at TMP, but it was my second time ever driving there, and in a car I literally jumped into and was forced to get a lap time within 3 laps. I am sure with at least a session of practice I could have gone faster. It was a 97 328is with TCK coils and super heat cycled out Yoko slicks (and a 3.23 diff FYI). I probably could have gone faster on R comps right out of the box as those slicks take a few laps to heat up
Old 07-09-2012, 10:59 AM   #22
sb_600
sb_600's Avatar
Haha you sure?
Then it's even more about the driver!
Shawn
Old 07-09-2012, 12:31 PM   #23
Nolimit77
Haha you sure?
Interesting, I have an option to go to the 3.23 but I don't think it is enough as I am currently using a 3.15. My car is running on 255 Hankook RS-3's and OEM shocks/H&R spring setup due to the class I am in. Unfortunately I haven't optimized the car yet due to lack of funds but I won this past event by 1.1 seconds(2nd place guy was also driving my car) so I am very happy to say the least. Track record for my class is 1:22.7 and next time we go, I plan on changing that!
On a seperate topic, anyone ever have a belt shift in their tire? It was the only problem I suffered the entire event- seems like the left front just gave up completely due to being run consecutively all day. Started to get a big vibration on the straight and even more when turning right so we swapped it to the rear and I had less vibration in the steering wheel but more in my butt. Was able to go quicker once we did the swap but I still felt nervous through turn 1-2.. Thinking of just going with a new set seeing as how mosport is the venue for our next event.
Old 07-09-2012, 04:59 PM   #24
I had a belt shift on some Kumho street tires that I ran on my old E30... It happened at Mosport, and seemed to happen almost instantaneously (almost from one lap to another). I didn't know what it was at first, I figured maybe the wheel was loose or something because it was way worse than a missing wheel weight. It developed a bump on the inner section of the thread, about half way around the wheel. Interesting experience, but I didn't feel confident driving on that set anymore so I just gave the 3 remaining ones to a buddy to drift on. Definitely recommend to get a new set of tires for a higher speed track like Mosport.
Old 07-10-2012, 02:26 AM   #25
doogee
doogee's Avatar
Racewars. It's on. Lol
Dakar M3 Track Build Thread
Old 07-10-2012, 10:41 AM   #26
sb_600
sb_600's Avatar
I can't wait - My parts are being overnighted from Japan as we speak.
Shawn
Old 07-10-2012, 11:10 AM   #27
doogee
doogee's Avatar
Perfect. Hopefully I can get my diamond plate floor riveted back in by Thursday. It mysteriously fell off in a previous battle.
Old 07-10-2012, 11:29 AM   #28
sb_600
sb_600's Avatar
Too much boost!!!
Shawn
Old 07-10-2012, 11:32 AM   #29
Be careful of the welds on your intakes guys!
Old 07-10-2012, 11:43 AM   #30
exbmwtech
No granny shifting
exbmwtech is offline   Reply With Quote
