Old 09-10-2012, 01:29 PM   #76
sb_600
sb_600's Avatar
^ while I was drinking beer inside
Shawn
Old 09-10-2012, 08:26 PM   #77
captain E34
Sliding Sideways
captain E34's Avatar
so first we got the .130 mls head gasket
Then we have a magnaflow cat and muffler
with only a couple or so hours of working on the car me and maxbell have come to this!!
just picked up a couple tools to continue removing the head, and also ordered some VAC exhaust manifold studs and nuts, valve cover gasket, and some high temp ngk spark plugs BKR7E is the part # i believe
__________________________
1988 535i M30 (Turbo Build)
1989 535i M30 (Beater)
1990 520i Soon To Be S52 (Turbo Build)
1994 525it M50 (Beater)
2005 X5 M64 (Daily)
2009 335i (Daily)
The Rest Is History...
We shall seek who discover mo powa via the wheels (Shakespeare)
QUOTE FROM THE WISE... "Gap is something all the girls want and all the guys want gone"
captain E34 is offline   Reply With Quote
Old 09-11-2012, 08:07 AM   #78
Chris916
Chris916's Avatar
Project is coming along nicely! Keep it up!
Nice find on the e28, love those cars.
Track - 1991 318is - My Track Car Build
Street - 1987 340i - E30 M60 Build
Chris916 is offline   Reply With Quote
Old 09-11-2012, 10:02 AM   #79
Looking good! Are those plugs one step colder than what is called for?
Old 09-11-2012, 10:27 AM   #80
sb_600
sb_600's Avatar
^ Yup - the 6E is recommended, but you can use 7E as well.
Shawn
Old 09-14-2012, 10:59 AM   #81
captain E34
Sliding Sideways
i thot the 7e was for higher temps?
and im now stuck on one head bolt that i do not have a deep e8 for, princess auto here i come!!
also i got my 2x 3000 cfm aux fans mounted (pics soon) and i am still running the stock clutch fan, only problem is most people run the fans threw the coolant temp switch for the a/c..... mine has no a/c , so im kinda wondering if i should simple run them constantly on or if i should put a switch or something.... any ideas?
i cut out a sec. of plastic on my front valance (i think its called) for air flow to the i/c! and it actually looks good and oem, just gotta clean up the edges
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 09-14-2012, 06:11 PM   #82
HavocSteve
For my clutch fan on the E30, i just rigged it nicely to the fuse panel, and hook it up with a switch. So if it started to get hot, I would just flick it on. Or leave it on whenever the car was running.
Old 09-17-2012, 06:57 PM   #83
captain E34
Sliding Sideways
Ya i will probboly just run them through a switch and be done wit it lol
Soooooo i got my tools and i lossened all the head bolts, only issue is i have no one to hold my timing chain while i lift the head off i have a fear or it just falling into my engine if i try and do it alone!! D:
these r ma photos of the fan and cut up valance
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 09-25-2012, 05:39 PM   #84
captain E34
Sliding Sideways
sooooo its all bvack together!! i was so excitied to get it bck together i forgot pics soooo anyways ill be starting it tonight with the new head gasket! illl pos a video later, hope it all works out!
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 09-25-2012, 05:45 PM   #85
bmwconnect
BMW Tuner
bmwconnect's Avatar
I have been busy wow I feel like I missed a lot of action here. will be waiting for vid
Old 09-25-2012, 08:15 PM   #86
captain E34
Sliding Sideways
so here it is, ma first start with ma new head gasket..... it neeeds a tune or i got the timing chains wrong
ps. sorry about the shitty sound, it only has the manifolds so u better turn down ur speakers and i was putting in the fuel pump fuse if anyone was wondering lol
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 09-25-2012, 08:17 PM   #87
bmwconnect
BMW Tuner
bmwconnect's Avatar
Your not running the 42Lbs in there right now are you? In the video rather
Old 09-25-2012, 08:18 PM   #88
captain E34
Sliding Sideways
nooope
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 09-25-2012, 08:59 PM   #89
captain E34
Sliding Sideways
how do you tell if the positioning of the timing chains and sprokets are proper? i turned the engine over by hand when it was just put back together and nothing came in contact with anything soo i felt as if it was all good.
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 09-26-2012, 01:20 PM   #90
sb_600
sb_600's Avatar
It's not just about things coming into contact....
Take your valvecover off and rotate it until cylinder 1 is at TDC - the two cam lobes should be pointing at each other & the tops of the squares should be level or almost level to the head. You're likely off by a tooth or two and didn't notice the first time...
Shawn
