Old 08-05-2013, 01:43 AM   #421
captain E34
Sliding Sideways
captain E34's Avatar
I picked up some toys, I bought the moates burn 2 and the ostrich 2.0 emulator, ive been wrkin away with it, I seemed to have got it set up well, I can run my laptop off the emulator while driving, and trace the values on the graph. im new to the tuning scene but I learnt to adjust rev limiter, a/f ratio (somewhat) haven't tried messing with timing just yet, oh the emulator is in permanently and is replacing the tuned epprom chip barrie had made for me. the ostich is running the same tune barrie created
edit: I did adjust the injector constant to through a little more fuel and it seems to be working. haven't run into any issues
__________________________
1988 535i M30 (Turbo Build)
1989 535i M30 (Beater)
1990 520i Soon To Be S52 (Turbo Build)
1994 525it M50 (Beater)
2005 X5 M64 (Daily)
2009 335i (Daily)
The Rest Is History...
We shall seek who discover mo powa via the wheels (Shakespeare)
QUOTE FROM THE WISE... "Gap is something all the girls want and all the guys want gone"
captain E34 is offline   Reply With Quote
Old 08-16-2013, 06:27 PM   #422
Chris916
Chris916's Avatar
Pretty sure i just heard some magical turbo noises as you passed me on Merrivale about 20 min ago.. (white e30)
Car looks good dude
Track - 1991 318is - My Track Car Build
Street - 1987 340i - E30 M60 Build
Chris916 is offline   Reply With Quote
Old 08-16-2013, 07:19 PM   #423
captain E34
Sliding Sideways
Haha that was me
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 08-23-2013, 01:27 PM   #424
captain E34
Sliding Sideways
Btw chris nice e30
Ive been playing around with my tune!, not sure if anyone can tell me if this is true, if i adjust my injector constant to a higher value then stock, and reduce all the fuel maps to comoinsate for the added fuel will this allow me to run more boost on my maf due to the ecu thinkin there is "less" load on the fuel system? I did minor adjustment this way and i was able to add a psi of boost with no fuel cut
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 08-23-2013, 02:05 PM   #425
Depends on what cut fuel, and how it determines the level to cut at. If it's purely on the map value, yes, if its on the calculated final injector open time, no. If its based on too much air passing thought the MAF (likely) then it's not effected.
Old 08-23-2013, 02:07 PM   #426
captain E34
Sliding Sideways
I my maf gets overloaded due to to much air :/
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 08-23-2013, 02:23 PM   #427
Yeah, that happens. I wonder if you could run a bypass pipe around the MAF, halving the amount of air that goes through the MAF and then adjust the fuel (say, the injector constant) to put in twice as much fuel as it "thinks" it should have? Sounds dubious but could work.
Alternatively, you could build a MAF out of the guts of a 2" into a 3.5" body. You'd need to retune but it would likely work to some degree.
Old 08-23-2013, 02:56 PM   #428
captain E34
Sliding Sideways
I actually thot about dooin the pipe around the maf which would be wierd but might work!,
Im in the process of slowly rebuilding an extra maf i have into a 3.5 or 4 ince pipe... just been lazy
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 09-15-2013, 04:03 AM   #429
captain E34
Sliding Sideways
Pulled apart maf gunna cut the plastic housing and install it on a 3.5 - 4 inch pipe, theory is that the air traveling through the maf will slow down with the larger diameter and wont cause the hot wire in the maf to cool down as much with the same amount of air flowing.
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 09-15-2013, 04:14 AM   #430
captain E34
Sliding Sideways
Forgot to put pics of this install but here ma fuel pump and adjustable fuel pressure reg.
Fuel pressure reg. Installed (some random ebay fpr)
I bought this adapter to replace the stock regulator in the fuel rail
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 09-16-2013, 10:24 AM   #431
Saw you saturday night on Merivale.. sounded good.
Old 09-16-2013, 10:29 AM   #432
captain E34
Sliding Sideways
Thanks mate
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 09-16-2013, 06:18 PM   #433
captain E34
Sliding Sideways
I recieved my larger maf in the mail toooday! And picked up my rear wheel bearings at part source
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 09-20-2013, 01:45 AM   #434
bmwconnect
BMW Tuner
bmwconnect's Avatar
I leave and come back and things are just getting better. The maf change is key
Old 09-21-2013, 11:53 AM   #435
captain E34
Sliding Sideways
ya im just waiting on one more silicone boupler and im good to go on the install
2005 X5 M64 (Daily)
2009 335i (Daily)
