Old 06-24-2013, 06:20 PM   #406
captain E34
Sliding Sideways
captain E34's Avatar
Been looking at upgrading the extra cyclinder head I have with some supertech valve springs and s50 cams,
Supertech Springs = $550 ish depending on where I pick them up
s50 cams = around $300, saw a couple used sets for sale for around that price
been looking into a clutch upgrade, but I don't believe there is an upgrade for my tranny. I am unsure of the model or name of my tranny but I know its different then every other bmw's other then the e36 320i non a/c and my model which is also non a/c (according to realoem.com)... the a/c models have different flywheels and also have different trannys, it looks like im gunna get my clutch rebuilt with better materials so it can handle larger amounts of torque before it slips
p.s. George what was the crank you mentioned I should get? s50 crank?
__________________________
1988 535i M30 (Turbo Build)
1989 535i M30 (Beater)
1990 520i Soon To Be S52 (Turbo Build)
1994 525it M50 (Beater)
2005 X5 M64 (Daily)
2009 335i (Daily)
The Rest Is History...
We shall seek who discover mo powa via the wheels (Shakespeare)
QUOTE FROM THE WISE... "Gap is something all the girls want and all the guys want gone"
captain E34 is offline   Reply With Quote
Old 06-26-2013, 08:57 AM   #407
George77
George77's Avatar
You can use any crank from any US m/s 50,52,depends on what stroke you prefer.
George77 is offline   Reply With Quote
Old 06-26-2013, 10:15 AM   #408
captain E34
Sliding Sideways
u mentioned one specifically when at m&ms sayin it would be the best for my setup.... just wanted to do some research on it
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 06-26-2013, 11:38 AM   #409
George77
George77's Avatar
For your boat the longest stroke is ideal,so try to look for a s52 crank.I might have an s50 which is 85.8 mm stroke,should be good too
Old 06-27-2013, 12:58 AM   #410
captain E34
Sliding Sideways
What does the longer stroke help with? Wouldnt it make more compression?
Im not sure what stroke the m50b20 has either... ill do some research
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 06-27-2013, 01:05 AM   #411
captain E34
Sliding Sideways
Found out my stroke is only 66mm, i could even upgrade to a m50b25 crank which would give me 75mm.
Along with the crank do the rods need to be replaced? Im thinkin if the piston throw is longer it will throw the piston into the hesd or valves... am i right?
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 06-29-2013, 12:24 AM   #412
George77
George77's Avatar
Yes,depending on which crank you use,you need the proper conrods and pistons.
Old 06-29-2013, 12:47 AM   #413
captain E34
Sliding Sideways
Will i be able to keep my 80mm bore postons with a different crank amd connecting rod set?
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 06-29-2013, 09:56 PM   #414
captain E34
Sliding Sideways
Messed up stuff happend, my friend was infront of me and a drunk driver rear ended him and took off, so i followed him, he turned down a side street floooooored it and when he came to a turn he understeered and hit the curb.... worse then that.... he hit the curb and bounced off and hit a mazda head on at like 80 km+, everyone is ok, but in the end i got a ticket for careless driving... pretty much cuz i followed him at high speeds while i tried to get his plate number, sooo if i dont beat the ticket in cpurt, no more licence for a while and hopefully i can wrk on ma car a bunch
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 07-03-2013, 08:51 PM   #415
captain E34
Sliding Sideways
while checking for booooooost leaks, which I found, I noticed my oil going..... blurp bupblurbub plop burb..... my boost is somehow getting into my crank case and bubbling my oil.... how is it doooing this? what part of the car gets + air pressure inside the oil?
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 07-04-2013, 11:02 AM   #416
ju_le_new
Whooa. That's a weird story, glad everyone is ok! What did the drunk guy said when he got out of his car? I'd be mad angry at him, no regrets for drunk drivers...
ju_le_new is offline   Reply With Quote
Old 07-04-2013, 11:53 AM   #417
sb_600
sb_600's Avatar
How's your compression? rings maybe?
Only other thing I can think of is HG (getting in through the oil passages), or possibly your CCV, but I can't remember how you vented it...
Shawn
Old 07-05-2013, 02:06 PM   #418
captain E34
Sliding Sideways
soo i figured out my boost is leaking through my turbo into my return line which foams my oil and is making my oil pump run dry
i dont believe my turbo is supposed to do this lol, ive nvr herd of it before but i dont have a lot of experience with it.
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 07-05-2013, 02:52 PM   #419
Well I'd say typically both seals go bad, which is when you start seeing smoke out of the exhaust pipe because you're burning oil. However I guess it would be possible for only one seal to go bad which would cause blow by to exit via the oil return. This could also be bad because it may prevent oil feed to the bearing as well, although the chances of that are probably unlikely.
Is there any oil on the inside of your IC piping?
Old 07-05-2013, 04:04 PM   #420
captain E34
Sliding Sideways
The only problem im having is that the car only did it when i replaced my old turbo with this one. My old ebay turbo didnt make my oil foam but this one started during the first drive after i installed it. I thot it was oil foaming but i wasnt sure how it was foaming. I contacted tcd but he said my turbo isnt my issue. Which makes no sense cus i blocked off the intake and pressurized only the turbo.
2005 X5 M64 (Daily)
2009 335i (Daily)
