Old 06-11-2013, 10:30 AM   #391
captain E34
Sliding Sideways
captain E34's Avatar
Thaaaaank you
__________________________
1988 535i M30 (Turbo Build)
1989 535i M30 (Beater)
1990 520i Soon To Be S52 (Turbo Build)
1994 525it M50 (Beater)
2005 X5 M64 (Daily)
2009 335i (Daily)
The Rest Is History...
We shall seek who discover mo powa via the wheels (Shakespeare)
QUOTE FROM THE WISE... "Gap is something all the girls want and all the guys want gone"
captain E34 is offline   Reply With Quote
Old 06-11-2013, 06:32 PM   #392
bmwconnect
BMW Tuner
bmwconnect's Avatar
I like~
Old 06-11-2013, 06:36 PM   #393
captain E34
Sliding Sideways
Barrie when are u free next to see if i can boost some more?
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 06-12-2013, 09:35 PM   #394
George77
George77's Avatar
How much beust so far???
George77 is offline   Reply With Quote
Old 06-12-2013, 10:37 PM   #395
captain E34
Sliding Sideways
Before maf cuts out about 6-7
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 06-14-2013, 01:08 PM   #396
captain E34
Sliding Sideways
got the fronts mounted on rims gunna install tonight for m&ms and give her a bath
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 06-14-2013, 01:11 PM   #397
ju_le_new
Oh yes ! I might stop by tonight since the weather is so good, and have a closer look at the build
ju_le_new is offline   Reply With Quote
Old 06-14-2013, 05:46 PM   #398
bmwconnect
BMW Tuner
bmwconnect's Avatar
I might be there
Old 06-18-2013, 11:20 AM   #399
captain E34
Sliding Sideways
Alriiight so ive run into an issue with might be wheel alignment or something!!,
With my 195 65 15 basket weaves with 20et offset not a trickle of vibration,
With my 225 40 17 style 5's with the same offset dont vibrate in the rear, in my opinion rules out balancing but shakes when installed in the front, mostly under braking around 100 ish,
I put the front to the back and still the same thing, fronts shake years dont :/
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 06-18-2013, 09:24 PM   #400
captain E34
Sliding Sideways
Stupid me forgot aboot the hub bore difference :/ lol faaaaack....
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 06-18-2013, 09:38 PM   #401
Usually the vibration under braking at 100 is the control arm bushing, which isn't strong enough to hold the arm in place when lateral load is applied in the reverse direction. My 540i did that too.
It's more pronounced with wider tires.
Old 06-18-2013, 10:10 PM   #402
captain E34
Sliding Sideways
Yaaa they r new!! But as i mentioned i forgot aboot the different bore sizes with the style 5s, should resolve my issues!
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 06-19-2013, 03:30 PM   #403
ju_le_new
Yup that should fix it! Put some anti-seize on them or you will have a bad time
Old 06-19-2013, 06:58 PM   #404
bmdbley'sBro
wouldu like some tinfoil?
bmdbley'sBro's Avatar
everlast's point is correct, even New, factory has large gaps allowing for play.
the bor differance is like 1mm cut up a margerin container & make a ring or get some from 1010tires.com.
also can get the shake from even Slightly warped rotors, happened to me
Old 06-20-2013, 08:16 PM   #405
captain E34
Sliding Sideways
I ordered the rings should be in next week
Just ordered walbro 255lph fuel pump also gunna order a 3.5 bar fuel pressure reg. If my adj. Fuel pressure reg. Doesnt fit
Also looking at a intake temp sensor as well as an egt sensor ..
Gunna do some diagnosing of my oil pressure regulator as well
2005 X5 M64 (Daily)
2009 335i (Daily)
