Old 05-17-2013, 08:34 AM   #346
captain E34
Sliding Sideways
captain E34's Avatar
Beautiful
__________________________
1988 535i M30 (Turbo Build)
1989 535i M30 (Beater)
1990 520i Soon To Be S52 (Turbo Build)
1994 525it M50 (Beater)
2005 X5 M64 (Daily)
2009 335i (Daily)
The Rest Is History...
We shall seek who discover mo powa via the wheels (Shakespeare)
QUOTE FROM THE WISE... "Gap is something all the girls want and all the guys want gone"
captain E34 is offline   Reply With Quote
Old 05-18-2013, 08:13 AM   #347
George77
George77's Avatar
I am waiting for VIDEO,do not forget to get some.
George77 is offline   Reply With Quote
Old 05-18-2013, 10:53 PM   #348
bmwconnect
BMW Tuner
bmwconnect's Avatar
Got her running nice and smooth on 42LB injectors. There is some thing's that need to be done and then will go back to the tune.
Reminder: Oil restrictor, Boost Leak down test , video of AFR, Boost , RPM
Old 05-20-2013, 01:47 PM   #349
captain E34
Sliding Sideways
Tryna get it all done, locating an oil restrictor online but am gunna check out ottawa fasteners in b.c. seems to be running pretty good, gotta and a couple things and we should be gooood
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 05-20-2013, 10:11 PM   #350
Oil restrictor is easy.
Go to ottawa fastener, to the metric fine section and find a bolt that threads into your oil inlet port. You'll find that its threaded on the inside for some reason. (Nearly all are.) Usually nothing screws into this as the oil inlet port bolts OUTSIDE it.. so buy a bolt that fits it in the hole, cut it and cut a slot on the face so you can screw it in with a flat head.
Then drill a small hole in it.
Done!
Old 05-21-2013, 07:34 AM   #351
bmwconnect
BMW Tuner
bmwconnect's Avatar
Done!
I'm hoping with the restrictor in place the oil pressure will be diverted back to the head. After high rpm pulls the head ticks SO LOUD and then calms down after a few minutes of idling. The oil pump is probably on it's last leg's too.
Old 05-21-2013, 10:12 AM   #352
With all the oil channels in a head, I don't think that the 1/4" line going to the turbo will make a difference to the overall pressure.
If that's the problem, get an oil pressure gauge. Should have one anyway! The turbo should only have an oil restrictor if it specifically calls for one.. Ask Todd at TCD if that's the case.
Old 05-21-2013, 05:34 PM   #353
captain E34
Sliding Sideways
is it possible that my oil is foaming up? i dont have the oil return set up the "proper" way soo instead of the oil draining onto the top of the oil in the pan its returning into the side of the oil pan, possible issue?
and since it only started ticking with the new turbo my conclusion is that the old turbo didnt spool enough to make the oil foam, but as soon as i replaced the turbo for the smaller one, it ticked from the beginning! , i have another oil pan that im gunna remove from my other 520i sooo ill get a proper oil return bung welded in
oh btw... i have a oil pressure gauge but its not working i figure its not wired properly , lights up and everything but doesnt recieve a signal from the sensor
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 05-21-2013, 05:42 PM   #354
Weird.. I can't see that being the problem, but you never know. *something's* causing it. :/
Old 05-21-2013, 05:44 PM   #355
captain E34
Sliding Sideways
yaa its wierd, with my old turbo it never ticked..... i swapped it, ticked after first pull, ive tried different oil weights from 10-30 to 20-50, with the thicker oil, it ticks alot more, thinner oil doesnt tick as much but still ticks
cruising in the gatineau hills yesterday, of course not going any faster then the sped limit , it was ticking like crazy when i got to the bottom pulled into the gas staion to wait for a friend who i guess was going the speed limit, i mean..... slower then the speed limit, and the ticking went away :/
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 05-22-2013, 01:27 PM   #356
George77
George77's Avatar
It's the high temperature or you are low on oil.Make sure you run a 80 deg thermostat, if you run the 89 the engine will be at least 10 deg hotter and then don't run 5w30 oil in it, run the hot side of the oil thicker like 40 or 50.In less words your head runs very hot after puls
Old 05-22-2013, 01:40 PM   #357
captain E34
Sliding Sideways
my car runs pretty cool, never reaches mid point on the stock coolant temp gauge, and even with thick oil it ticked worse then with thin, I can try adding some oil but the level seems fine
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 05-26-2013, 12:30 PM   #358
bmwconnect
BMW Tuner
bmwconnect's Avatar
How she running? Get the issues taken care of? ready to up the boost?
Old 05-27-2013, 11:02 AM   #359
captain E34
Sliding Sideways
Im going to do the boost leak test today, ticking i havent fixed yet
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 05-28-2013, 12:00 AM   #360
bmwconnect
BMW Tuner
bmwconnect's Avatar
How did it go?
