Go Back   maXbimmer Forums > Specific Regional Topics > Quebec/Gatineau/Ottawa
Old 03-13-2013, 11:23 AM   #271
Originally Posted by captain E34 View Post
Third one looks like it.... ill contact them and get the demensions thanjs buuuuddy
I think they're all the same dimensions; its a pretty standard thing. I'd get whatever is cheapest, honestly.
Old 03-13-2013, 11:35 AM   #272
captain E34
Sliding Sideways
captain E34's Avatar
Wow, thats actually a great idea, i woukd have just picked up a gasket but with that sheet of copper i coukd make some other gaskets aswell!, thanks again, in ill let ya know about that flange... its the last piece to my exhaust puzzle
90' & 91' Imported E34 520i's, 94' E34 540i
QUOTE FROM THE WISE... "Gap is something all the girls want and all the guys want gone"
captain E34 is offline   Reply With Quote
Old 03-13-2013, 11:37 AM   #273
I'd offer up some unused stuff I have, but its buried in the back shed or garage somewhere.
Old 03-13-2013, 02:32 PM   #274
sb_600
sb_600's Avatar
i was told to only use the wall mounted ones due to some safety concerns i dont want a smashed jaw from my strut mount flying off
pfft.... last time I wrapped a strap around the spring, brought it outside and pointed it at the trees. came off no problem, and my jaw is intact
Shawn
Old 03-13-2013, 04:01 PM   #275
Yeah, if you use both sides of the clamp, you can have a failure and it still doesn't fly apart. Honestly, its not as bad as people say. Just don't be dumb.
Old 03-13-2013, 10:05 PM   #276
captain E34
Sliding Sideways
I guess i can understand that haha, i guess ill just take a look at partsource or c.t. like u said.....
Lol aimed for the trees eh? i guess thats better idea then accidently hittin the side of ur car!
Old 03-13-2013, 10:13 PM   #277
captain E34
Sliding Sideways
Just bought that obx exhaust flange haha, if the 4 bolt holes arent in the right spot ill drill new ones
Old 03-13-2013, 11:11 PM   #278
There ya go!
Old 03-13-2013, 11:15 PM   #279
captain E34
Sliding Sideways
Should be in, in about a week or so, ill start putting the bends together then bring them to my friends for welding
Old 03-13-2013, 11:18 PM   #280
Right on. Princess Auto have an awesome pipe cutter which works well for this purpose. Kind of works like a pizza cutter or copper water pipe cutter. You can easily cut 90* corners into whatever angles you need.
You must be getting excited!
Old 03-13-2013, 11:23 PM   #281
captain E34
Sliding Sideways
I actuall have this saw for cutting steel uncle gave it to me cuz he had no use for it, soo i can cut my pipes with that
Im pretty excieted, yes ,
My alternator went in my beater 520i so i grabbed the turbos alternator, as well as the o2 sensor gunna grab a new o2, and swap the alt. Back when the nicer weather comes
Old 03-14-2013, 01:05 AM   #282
I have a 14" metal saw but it didn't make accurate cuts at all, so if you have trouble getting a smooth clean edge, check out the PA cutter. It made cuts cleaner than a factory cut edge.
Old 03-14-2013, 11:17 PM   #283
captain E34
Sliding Sideways
whats a pa cutter?
also got a bit of work done!!.... bought a$30 coil compressor set from princess auto and got the strut inserts out of the housings!!, gunna bring the housings to work tomrrow and cut them!!
Old 03-15-2013, 12:33 AM   #284
PA = Princess Auto.
http://www.princessauto.com/pal/prod...e-Cut-Off-Tool
Old 03-15-2013, 08:37 AM   #285
captain E34
Sliding Sideways
Wow, i saw that tool there and totally over looked it!, gunna go back tonight and pick it up!
