Welcome to!
Old 06-19-2012, 12:52 AM   #1
Proper Headlights Aim
Does anyone have any information on how to set headlights to get maximum performance from lowbeams.
Pedro is offline   Reply With Quote
Old 06-19-2012, 01:18 AM   #2
Any shop that can do a safety should have the equipment to do a proper adjustment. Its not expensive, and better get done right (the first time!)
Old 06-20-2012, 11:44 AM   #3
For vertical adjustment:
1. Drive up to a wall, and have at least 25ft of level ground from that wall.
2. Measure the height from the ground to the middle of your low beam headlight. Use tape to mark this spot on the wall that corresponds to the height you measured.
3. Reverse the car 25 ft from the wall.
4. Start with the driver side headlight, the bottom of the headlight beam should then be adjusted so that it is 2 inches lower than the bottom of the tape that you've marked on the wall.
5. Once the driver side has been adjusted vertically, the passenger side is easy, just adjust it so that it is at the same level as the driver side.
toy4to is offline   Reply With Quote
