Old 05-03-2012, 09:37 AM   #1
captain E34
Sliding Sideways
captain E34's Avatar
is this a good way to go?
hey guys i have a 1990 520I and im looking to turbo it over the winter along with paint and some other things, i am wondering if the turbo (somewhat) kit is a good buy to build off of. also what else will i need? i will be adding intercooler not sure of demensions of it but for now just wondering about the turbo (somewhat) kit.
http://www.schmiedmann.es/TURBOBASKI...uctnumber.aspx
Old 05-03-2012, 03:51 PM   #2
S52/S54 swap and you are done.
Old 05-03-2012, 06:30 PM   #3
captain E34
Sliding Sideways
Really? Just swap it out and it will be better then the turbo? Will it mount up the same and will it mount up to my getrag 260 tranny?
__________________________
1988 535i M30 (Turbo Build)
1989 535i M30 (Beater)
1994 525it M50 (Beater)
2005 X5 M64 (Daily)
2009 335i (Daily)
The Rest Is History...
Old 05-04-2012, 09:40 AM   #4
captain E34
Sliding Sideways
Would it be better tp purchase a 540? Like mid 90's?
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 05-04-2012, 11:59 AM   #5
What motor is in the 520?
Old 05-04-2012, 01:28 PM   #6
captain E34
Sliding Sideways
m50b20 150hp i would like to make it atleast 200hp, i could just swap for an m30, wit 208hp but i like that its the original euro engine not found in canada or the states, and the feul consumption on an m30 is rediculous!!
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 05-04-2012, 01:38 PM   #7
I'm not sure if the manifold is the same as the b25. If not, you'll have a really hard time tracking down a manifold for it, likely needing a custom one made. Be prepared for loads of work, learning and unexpected turns with a turbo.
Why not swap a m50b25 in? Probably a straight swap, close to 200hp.
Old 05-04-2012, 02:28 PM   #8
captain E34
Sliding Sideways
Well the link on my first post shows a basic kit that includes a turbo exhaust header also a turbo and partial install kit, i believe ill need an intercooler and intake, also low comp pistons and short connecting rods to get a lower comp. ratio
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 05-04-2012, 02:29 PM   #9
captain E34
Sliding Sideways
If im gunna do all that new injectors and higher pressure fuel pump is in order, i wanna stay away from engine swaps, but like if its my only choice then ill just pick up a 540i later in life
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 05-04-2012, 05:14 PM   #10
You certainly don't need to open the bottom end. Heck, you probably don't even need to remove the head. Low comp pistons, etc, or not necessary at all for a 200hp goal.
You'll need:
-manifold
-turbo
-oil feed
-oil return
-intercooler + piping
-bov / wastegast
-exhaust (downpipe, merge into exhaust)
-fuel injectors
-engine management
-loads of time
Pretty much it really.
Old 05-04-2012, 08:00 PM   #11
captain E34
Sliding Sideways
Thats all i want pretty much, and that seems completly doable! Is the turbo kit i posted a good way to go?
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 05-10-2012, 02:23 PM   #12
captain E34
Sliding Sideways
so the onlything i need to find now are the fuel injectors, where would i look for those? and what size or pressure should i get?
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 09-19-2012, 08:49 AM   #13
Kamil
Däs Klässe
Kamil's Avatar
would the 2.8L injectors work for a setup like this or for my 323ci?
Kamil is offline   Reply With Quote
