Old 06-06-2012, 12:00 AM   #1
jay01_brown
OBSERVE
Taking a little longer to start in the morning (cold start only)
This has been going on for the last week or so....
Every time i cold start the car, she takes a little while longer (holding the key in position) to start.
Is this a sign of anything?
Starter?/battery?
The dash is showing that i have an oil service due. Would this play into any of it?
getting the oil changed this weekend
Any help guys
J
jay01_brown is offline   Reply With Quote
Old 06-06-2012, 12:32 AM   #2
Blackedout95
No, get your battery checked when you go in for the oil, if it checks out go on from there, starter should be more obvious but also alt. could be the issue. If all those check out it comes down to the basics, fuel pump/filter etc but would be a consistant start issue not periodic (just on start up).
E46
Old 06-06-2012, 10:20 AM   #3
SiR
Vtec just kicked in
^^ start with the battery and go from there. After that it could be any number of things so you have to check various things out. (coolant temp sensor on the head could also be a culprit to hard start and is often over looked)
-||Old Crayons||-
Old 06-06-2012, 07:08 PM   #4
iverson03tj
iverson03tj's Avatar
what does the coolant temp sensor on the head have to do with it?
PREVIOUS CARS
Old 06-09-2012, 10:05 AM   #5
jay01_brown
OBSERVE
yes, id like to know as well.
Also, there is a three beep chime that comes on every other day or so...
i was told that this has something to do with coolant.
There are no check engine lights on, but still i would like to figure this out
