Old 06-11-2012, 03:47 PM   #1
jrat59
jrat59's Avatar
Subframe recall
Hey guys,
so I called BMW Canada this morning to see what the story was with the recall, they told me it was only in the U.S.
Im pretty sure I have read online in forums etc that it was more than just the U.S.
Anyone have any ideas or has had the work/inspection done to their car??
Trying to figure out if they're just jerkin me around.
'05 330ci ZHP - baby
'02 wrx wagon - winter beater LOL
'00 Jeep Grand Cher LTD - Sold
'01 S4 - Sold
'98 B18T Civ - Sold
'96 Jeep Grand Cher - R.I.P.
jrat59 is offline   Reply With Quote
Old 06-12-2012, 01:32 AM   #2
ac_2007
Cruising in Top Gear
ac_2007's Avatar
Read my thread here: http://forum.e46fanatics.com/showthread.php?p=12197293
Originally Posted by ac_2007
Fellow fanatics, today I contacted BMW Canada @ 1-800-567-2691 and spoke with a representative about the common subframe damage problem. For anyone in Canada wondering if the class action lawsuit applies here as well, let me clarify. Legally, the lawsuit only applies federally, meaning the United States.
However, I was told that BMW is offering the inspection in Canada as well, as a courtesy to all E46 owners. There shall be no charge for inspection and repairs. It is unclear if they provide you with a loaner car, should you have this issue, but most likley up to the discretion of the specific dealership.
Furthermore, in Canada there is no apparent deadline for inspections/repairs, granted the sooner you take care of it, the better. It is advised to contact the dealership and discuss/ book the appointment, since the program is not as well known here.
Good luck to all, hopefully nobody will have issues obtaining the inspection.
Old 06-12-2012, 07:38 AM   #3
jrat59
jrat59's Avatar
So what should I do? call BMW Canada again or a dealer? what exactly should I say to BMW Canada?
They told me that we are basically shit out of luck when it comes to the subframe problem in Canada.
I dont understand how they can just let our cars stay mangled if there is a problem that they created.
Ugh fml.
'01 S4 - Sold
'98 B18T Civ - Sold
Old 06-12-2012, 04:20 PM   #4
ac_2007
ac_2007's Avatar
Although there is no finite deadline, it would have been much more beneficial to go do the inspection before the period expired in the states. I believe that was somewhere in Sept/Oct 2011.
Different dealerships will give you different answers. Some (willingly or not) will not know anything of the issue, while others might give a helping hand. I'd call BMWNA and try to negotiate with them to give the go-ahead for an inspection. Use the scanned image another member posted up in that thread as leverage when you go in person.
I'm curious though, you have a 330, why do you think you're having subframe issues?
Old 06-14-2012, 11:20 AM   #5
pawelgawel
OP...
this problem was only in the early stages of E46 batch (1999-2001).
Seeing you have an 05 330, I wouldn't worry about this at all.
If by some chance the subframe is damaged, in FULL STOCK suspension components on the car, go to one of the BMW dealers in your are and present the problem. Don't ask questions... be curtious but firm that this is a common problem with e46 and it should be covered by BMWNA.
Don't show attitude, just explain what is happening and see if they are willing to help.
pawelgawel is offline   Reply With Quote
Old 06-14-2012, 11:24 AM   #6
jrat59
jrat59's Avatar
Originally Posted by pawelgawel View Post
OP...
Thanks, this helps... will try that. IF there was a problem with the subframe, would there be something I would notice during driving or anything like that?
'01 S4 - Sold
'98 B18T Civ - Sold
Old 06-14-2012, 11:41 AM   #7
It is not true that the subframe problem only affected early e46's. All E46's are affected. (as are e36's, Z3's, etc).
BMW still doesn't know how to make a subframe that wont incinerate itself.
Old 06-14-2012, 12:07 PM   #8
pawelgawel
That is very true... but I never heard of anyone in the 2003+ years have this issue thus far. From what I read they used a bad metal composition for a while and the problem was fixed once they brough in new sheet metal for later years.
OP..
search and google this issue... you cant miss the damage if its big enough. Sometimes you will have a ckrack that is unnoticable due to the thick undercoating.
Lift your car in the rear high enough so you can have a good look. take a flash light and inspect the four subframe bushings and the points of the floor that the bushing is bolted on to.
But like i said, it would be a real bad luck if you had this... only about 5% of all E46 have this issue.
Old 06-14-2012, 12:12 PM   #9
jrat59
jrat59's Avatar
Beautiful...
Thanks for the info.
Anything while driving that would give away that there might be problems??
'01 S4 - Sold
'98 B18T Civ - Sold
Old 06-14-2012, 01:01 PM   #10
pawelgawel
cricking/thumping sounds, but thats in the far stages once the floor actually rips and the motion of the torque pulls and pushes the frame.
Old 06-14-2012, 02:16 PM   #11
ac_2007
ac_2007's Avatar
The owner of a 328ci show car only noticed slight clunking noises at low speeds.
His subframe was completely obliterated though:
Again, you didn't answer why you think you need this inspection.
Old 06-14-2012, 02:31 PM   #12
Pawel, i have seen 03+ cars as well as M3's and other BMW's with similar subframe failures (including stock street cars).
Where are you getting your numbers from that only 5% of e46's experienced subframe failure?
Old 06-14-2012, 06:07 PM   #13
jrat59
jrat59's Avatar
Sometimes theres a little click, but I might just be paranoid... I think its more of the fact when I let the back end go its kicks back opposite way sometimes really rough.
'01 S4 - Sold
'98 B18T Civ - Sold
Old 06-14-2012, 06:09 PM   #14
jrat59
jrat59's Avatar
ac2007, do you have a pic from further out??? thats really zoomed in
'01 S4 - Sold
'98 B18T Civ - Sold
Old 06-14-2012, 07:35 PM   #15
ac_2007
ac_2007's Avatar
