Old 06-09-2012, 06:24 PM   #1
Carter
e30 325xi
Does anyone have any advice when buying the all wheel drive e30? Is it better to steer clear of these or are they just as reliable as their rwd counter part?
Carter is offline   Reply With Quote
Old 06-09-2012, 07:25 PM   #2
E36is
'OldSchool..'
E36is's Avatar
transfer cases are problematic mainly leaks and joints. If you are looking for one, look for a US model which came with 5spd and 2door coupe... canadian versions only came with auto and 4 doors. Rim offsets are unique with the ix, they have 40+ offset whereas standard e30 (except m3) came with +20 offset, someone correct me if im wrong. I believe the suspension is also unique for the ix as well.
Old 06-09-2012, 08:56 PM   #3
Ceeker
they also came 5sp in North America and some came with the sport interior and minor cosmetic upgrades. offset 15" basket weaves are Et41. joints are not the problem. the viscose coupling (transfer case) case have broken time to time but most the problem is the output shaft splines tend to strip causing the front wheels to intermittently work due to stripped spines or not all together. the weak point is the transfer case and one can test this by jacking the rear wheels up and putting the car in drive. if the car moves forward with out any slipping or skipping the transfer case is good. that means all 4 wheels are driving. it is a 70/30 splint rear to front.
A quick fix for the spine issue is tack welding the shaft to the output flange on the transfer case. will never slip again. the expensive fix is removal of the drive train from the motor back. everything has to come out. tranny, exhaust, drive shafts, diff. $$$$$
oh one other thing. Axle shafts boots tend to tear and lube leaks out eventually causing the cv joint to get dry and knock or chatter. would require replacement.
2 IX's -sold and parts
2 325i 4 dr - sold
1 87 325is red - parts
1 89 325i vert grey - parts
1 90 325is white - keepin
1 87 325i vert -red - keepin
Ceeker is online now   Reply With Quote
Old 06-10-2012, 10:22 AM   #4
supernaught
supernaught's Avatar
my ix is very reliable. Regular maintenance of the awd system and it will last just as long as any other e30. I've got over 400k on my dd auto ix, and aside from some rust, its been basically worry free for years. regular maintenance that includes inspecting the front struts, changing the fluids in the transmission, transfercase, and front/rear diffs(fluid change could be ever 3 or 4 oil changes).
Proper lubrication of the front driveshaft splines will keep a good shaft from slipping for a long time.
Front axle boots can be replaced with new grease if they are torn but the joint hasn't failed.
Front struts, steering rack, tie rods, control arms, subframe are unique, but front brakes are the same. Rear suspension is all very similar to rwd e30, but the rear rotors and hubs are unique.
They came in any combination of leather, vinyl, cloth, sport or comfort seats. 5 spd or auto. All of these were options. Most had the cold weather package(heated seats, mirrors, washer nozzles).
They are unstoppable in the winter with even half decent tires. But great tires will give you more confidence than a subaru.
They are marginally slower than a 325i, just due to the extra weight and rotating mass, but its barely noticable.
You can still stroke and boost an ix, just bear in mind the block, oil pump and oil pan are also unique. The rest of the engine is basically the same.
and its a 325ix. no such thing as a 325xi.
I've owned 5, some autos, some 5spds, some cloth sport seats, some leather comforts, they come in all combos.
Testing the AWD is a must though, like Ceeker said.
Good luck.
Old 06-10-2012, 01:15 PM   #5
JUICY J CAN'T
propr'one's Avatar
I beat the piss out of my 325iX for years, the only thing that ended up giving up was the M20.
I'd just add that "marginally" slower may be an understatement. My iX was chipped, 5spd, has some weight savings, etc, and it still much slower than a regular 325i.
hid headlights
Tags
325xi, all wheel drive, e30
