Old 06-02-2012, 06:26 PM   #1
desmo
AutoEmployee for Life
Sluggish performance after "spirited driving" M20
Second time this has happened and I was looking for some insight.
Took advantage of the rain yesterday and a large empty parking lot....Boy does an M20 like to shake it in the rain with shitty all-season tires...
I wasnt doing any crazy banging the rev-limiter 3rd gear drifts, but I was driving my car pretty hard for maybe 10 mins, ran flawlessly.
Then once I was finished and on the way home I had severe power loss between 2500-4000rpm. After 4k it cleared up again.
Pulled in a parking lot, turned it off, checked the oil, (spot on after recent oil change), temp was normal, waitied 5 mins and then drove home with no problem.
Any ideas? Didnt sound like a miss-fire, and I'm not too concerned because this exact same thing happend a month ago, and has been running normal since.
There is no better way to drive home from work than in an E30 that I can push from time to time.
desmo is offline   Reply With Quote
Old 06-03-2012, 08:43 PM   #2
mr ilia
Possible vacuum leak due ti increased temperature inside the engine bay due to spirited driving.
Likely some part/gasket change its properties due to higher than normal temperature inside the engine bay and gave the leak go. When engine cooled down everything returned back to normal, e.g. your motor started working proper again.
2004 BMW 325i, sedan, 5spd.
Old 06-03-2012, 11:04 PM   #3
Woofer
Woofer's Avatar
When was the last time the car had some maintenance done to it? I had similar symptoms last year, mainly on the highway or at WOT. It would only happen sometimes, more so on damp days.
This spring I did the spark plugs (mine were done!), wires, distributor cap and rotor (mine were toast after inspection), air filter, fuel filter and fuel injector treatment.
Now the car feels brand new. I haven't had any problems on damp days or during WOT.
I do however suffer from terrible gas consumption, but that's a whole other story. Lol
Hope this helps.
Old 06-04-2012, 11:56 PM   #4
desmo
Basic tune-up does seem like the ticket; to start with at least. Order's in!
Old 06-06-2012, 07:34 PM   #5
DR.ZED
Did you pull a plug to see if its fouled to heck?
Cam G.
85 325e M5
07 Honda Shadow Spirit 750
Old 06-08-2012, 06:30 PM   #6
desmo
Bunch of parts later and it is running better. I havent had any "spirited driving rain sessions" but it idle's a bit smoother and is noticeably better in the mid-range.
All OEM Bosch stuff. Plugs, wires, dizzy and rotor. Flushed the rad out well this week too, stays much cooler in traffic.
I've only owned this one just over a year and havent gotten around (or needed to do) much maintenance so all this was long overdue. I'm pretty sure I pulled the original cap off the car. (226km)
Old 06-08-2012, 07:03 PM   #7
Woofer
Woofer's Avatar
Good stuff!!! Wow that cap looks just as bad as the one I took out. Pretty sure mine was original too.
Did you give it any fuel injector cleaner? If not, should be next on your list. How does your air filter look?
Old 06-08-2012, 07:09 PM   #8
desmo
Air filter is fine for the moment. As for fuel, so far i've only dumped a few injector cleaners in the gas tank. We have some other fuel cleaner set-up at the shop that requires an air supply and disconnecting the fuel line to run the car off this "cleaner" Should get a filter as well and hook up my evap return line to the gas tank again. That'll be next week.
Then on to the rest of the list.....Doesnt everyone just love their PO's? And this thing was "formerly owned by a BMW mechanic" sure sure.
Old 06-11-2012, 01:56 PM   #9
desmo
This weekend's pickings. Solved my A/C problem. It is no longer broken, it doesnt exist!
Still have to remove the parts under the dash and a few more wires, but all the pipes are gone. Gotta be close to 30lbs. Also, I'm gonna re-install the a/c pushed fan, becase there is never enough cooling power in an M20 IMO.
Anybody think these old a/c lines/motor/condensor is worth anything?
Old 06-11-2012, 02:02 PM   #10
Woofer
Woofer's Avatar
LOL not sure what your plans for the car are, but if it's a daily you will miss that AC lol. Good luck! (telling you from experience!)
Nice e30 btw!
Old 06-11-2012, 07:21 PM   #11
mr ilia
Do you know if this a/c condenser is compatible with m42 engine?
Old 06-11-2012, 09:13 PM   #12
desmo
Most of my cars and all the E30's i've owned have lacked a/c. The E30 does pretty well in the window department though.
375km on Sunday on some roads North East of Orillia, around Queen EII Provincial Park. The car is pretty rough around the edges, but shows really nice.
Also, mr illia I'm not sure about M42 fitment.
