Old 05-31-2012, 07:36 PM   #1
lvan
lvan's Avatar
Flower dieing for no reason
Okay, I got this lil guy from Metro store to place it on my desk. So I gave him plenty of water, lots sunlight and what not, but it does not want to develop again as it were when I bought it... What could be an issue?
Old 05-31-2012, 07:44 PM   #2
Quack
Wheelman
Quack's Avatar
that looks like a pretty large plant for such a small pot, it probably needs more room to grow, put it in a larger pot with some better soil.
also make sure the area isn't too hot, especially dry hot areas, had a plant sitting on a old CRT TV long ago, the heat from the TV pretty much killed it.
Old 05-31-2012, 07:50 PM   #3
5style
Hatters gon Hatt
5style's Avatar
single season plant maybe??As in when its dead its dead
Old 05-31-2012, 08:07 PM   #4
check soil PH. you almost certainly want a bigger pot (transplant it leaving as much of the earth around it as possible to prevent shock.)
Overwatering and too much sun can be a problem too.
Old 05-31-2012, 09:46 PM   #5
lvan
lvan's Avatar
Yeah I looked at it inside, and it still has that seal pack around the plant. So when I removed it, and put it back in, there is a lot room for some more soil. That would be a good lead.
Old 05-31-2012, 10:02 PM   #6
Big Chin
Its an Orchid... It only blooms once a year... It doesn't need a lot of water at all... I was actually told that you should feed it ice cubes... They also do well in cooler temps so if you have had it outside... youuu probably cooked it...
Maxbimmer FeedBack
Big Chin is offline   Reply With Quote
Old 05-31-2012, 10:05 PM   #7
damameke
That's an orchid and from the yellow leaf, too much water
(the black pot - does it has hole at the bottom?)
water and make sure the water drains through the holes at the bottom
orchids like alot of light , but indirect sunlight...
You can trim that dead branch, leave about 6 to 8 inches from the bottom
hope that it will spring new buds..
hth
Old 05-31-2012, 10:22 PM   #8
lvan
lvan's Avatar
Correct, it has a hole on the bottom. I pulled off the seal and put in more soil just to feel up the gap as Ivan said. So I guess, I will make a hole in centre so water can flow all the way down.
hth
Old 06-01-2012, 01:58 AM   #9
ChrisTO
∞ Gear Member
orchids are the princess of flowers. damn hard to make it flower. have one and the thing just keeps growing my leaves but that's it! as others have said run water through it...
like dating a super model with a bad attitude. (i only wish i based this on experience )
ChrisTO is offline   Reply With Quote
Old 06-01-2012, 11:47 AM   #10
damameke
No soil.. use bark or charcoal, looking at your pathetic orchid
it will be a long while before it flowers again...lol
Old 06-01-2012, 03:07 PM   #11
Lmfao
Old 06-02-2012, 02:26 PM   #12
lvan
lvan's Avatar
Yeah, I will over the weekend when I have some time.
