Old 05-30-2012, 11:19 PM   #1
2low
help - turbo eta
hey guys iam boosting my 86 eta at the moment and i need help for the softwear. what do i use can i use my stock ecu? can i chip it and tune it for the turbo or do i need a stand alone ? iam not planing on going higher than 9 psi max
2low is offline   Reply With Quote
Old 05-31-2012, 01:34 AM   #2
Your best bet is to get onto E30tech.com. They're the boosting gurus.
Old 05-31-2012, 08:26 AM   #3
The problem with boost is that everyone says, "Oh I'm not planning on going higher than X psi..."
Then they drive their car and come back a week later saying they want more boost. It's addictive. But the point I'm trying to make is that there's enough knowledge and experience out there to pull from that you're better of spending your money on a DIY standalone kit that gives you the ability to tune for more boost than you'll ever be able to run than to spend money on a chip that's only good for one boost level.
I built a DIYPNP kit from diyautotune.com for my tuebo. It cost ~$500 including shipping + supplies (a cheap soldering iron, solder, and some wire). The kit was easy to build, you can do it in a weekend, and they even have base maps for a turbo 325i running 15psi which you can use to fire up your car.
Old 05-31-2012, 04:11 PM   #4
2low
there is so many types of DIYPNP which one did u pick
Old 05-31-2012, 04:20 PM   #5
e30_kid89
The Afro-stig
e30_kid89's Avatar
the one for 55-pin motronic ECU
Old 05-31-2012, 04:29 PM   #6
2low
it says its only from 87-91 but mine is a 86 do u think it will be the same ?
Old 05-31-2012, 04:35 PM   #7
2low
plus its an eta would it have the same pins as a i ?
Old 05-31-2012, 04:36 PM   #8
Assuming have a super eta (motronic 1.1) or you've done the "i" conversion to your eta (motronic 1.3). There is no PnP kit for the 35 pin motronic 1.0 that the standard eta cars ran.
Old 05-31-2012, 04:37 PM   #9
2low
yea iam screwed its a normal eta
Old 05-31-2012, 05:56 PM   #10
Yeah that 4800rpm redline isn't doing you any favours. Find someone parting out a 325i and get the parts you need to do the "i" conversion.
Old 05-31-2012, 09:04 PM   #11
matty.dc
matty.dc's Avatar
I've met him and already talked about this. Apparently he doesn't feel the need to listen to guys that have already built the cars.
2013 Ford Edge - Daily Driver
Old 06-01-2012, 03:11 AM   #12
2low
its not that i dont want to listen or els i wouldnt be askin for help i was just trying to see what kind of stand alone i need to use
Old 06-01-2012, 03:17 AM   #13
2low
there has to be atleast one way to boost that motor and tune it without converting to an "i"
Old 06-01-2012, 06:19 AM   #14
E36is
'OldSchool..'
E36is's Avatar
i have a 85 eta, not much can be done on these motors aside from the i conversion. best bang for the buck... LSx conversion. or convert to a GM 3.8L, which im thinking of doing.
Old 06-01-2012, 08:27 AM   #15
It's definitely doable. You can set-up an eta on stand alone, there's just no plug and play kits for them. You'll either have to hack up the wiring harness or gut the stock DME and work at fitting everything into that box similar to this...
FWIW, if all you want to do is a low boost application I'd recommend just swapping in an S50 or S52 motor instead because you'll make similar (if not more) power and still be able to insure the car. An aftermarket turbo is an instant denial of coverage for 95% of insurance companies.
