Old 05-25-2012, 10:16 AM   #1
jrat59
jrat59's Avatar
NEED HELP! tear in intake boot
Hey guys,
ordered a new part, you'll see the photos below...
just wondering if anyone else has had this issue and if I can just take out the air box to be able to get at it.
let me know what you think.
J
PS. no check engine light or anything. just the sound of the pressure is what gave it away.
'05 330ci ZHP - baby
'02 wrx wagon - winter beater LOL
'00 Jeep Grand Cher LTD - Sold
'01 S4 - Sold
'98 B18T Civ - Sold
'96 Jeep Grand Cher - R.I.P.
jrat59 is offline   Reply With Quote
Old 05-25-2012, 10:17 AM   #2
jrat59
jrat59's Avatar
sorry tried to resize them, they still came out huge
'01 S4 - Sold
'98 B18T Civ - Sold
Old 05-25-2012, 10:26 AM   #3
Yes, taking out the air filter box and disconnecting the connections to it will allow you to remove the rubber boot.
Old 05-25-2012, 10:25 PM   #4
vic325ci
vic325ci's Avatar
Does it make a whistling noise when you hit the gas? I think I might have the same problem
vic325ci is offline   Reply With Quote
Old 05-26-2012, 08:10 AM   #5
jabela
I had the same tear in my intake boot and it was making a whistle.
Here's a good DIY. It's pretty easy, though unclamping/clamping the engine side of the tube can be a bit tight.
http://www.bmw330ci.net/maintenance/tubeelbow.php
www.maisonapothecare.ca
Old 05-27-2012, 07:53 PM   #6
pawelgawel
you should replace both the bottom and upper intake boots after about 120,000km... I took my out at 150,000km and didn't have a rip but a large crack. their inexpensive $20 lower and $40 for upper, more or less.
pawelgawel is offline   Reply With Quote
Old 05-27-2012, 09:20 PM   #7
Blackedout95
Yes, common issue, easy to replace, should take you 20 minutes. And as stated it is a good idea to either replace or look over the lower while you are at it. It would eventually lead to idle/driving issues. Both boots and elbow locations crack and split often on everything I6.
GL
E46
Old 05-27-2012, 09:43 PM   #8
325iExecutiv
I had the same rip but also got the check engine light.
325iExecutiv is offline   Reply With Quote
