Old 05-19-2012, 11:44 AM   #1
SamE30e
SamE30e's Avatar
97 318ti CLEAN Cert & E-test
Hey,
The car is a 97 318ti, auto, silver. I purchased it off a co-worker, he purchased it off a customer. The vehicle came in last year with a blown rad. Turns out it was overheated and the head lifted between cylinder 1 and 2. I removed the cylinder head got it machined and re-installed.
The car has 246k on it, but it doesn't show it's age at all. It's one of the cleanest E36's I've seen, it would be a perfect daily driver for years to come or a perfect cadidate for a swap. There is no rust on the car, and it is actually getting [professionally polished and waxed next week.
I've put in all new OEM parts and services from the dealer that include:
Radiator
A/C and Serpentine Belt
Lower Control Arm Bushings
Heater Bowden Cable (common no-heat issue on ti's)
Brake flush
Coolant Flush
Air filter
Oil change (1000km ago)
Crankcase ventilation valve.
A/C service (Blow ice cold)
When I did the cylinder head I resealed the engine, it leaks no fluids. I used the revised camshaft timing for rough idle. This shifts the intake cam timing 6 degrees to smooth out idle. It's a BMW service bulletin for a common issue.
Everything works on the vehicle, it has heated cloth seats and a new CD player with iPod hook up that I just installed.
The vehicle passed E-test 2 weeks ago with flying colours and is still valid. I can work out getting the vehicle safetied. It won't need anything to pass. The only negative thing is the header flange is warped, so there is a small ticking noise when running. It needs a exhaust manifold, I can fix it if need be.
It also comes with a mint BMW winter tire package.
I'm asking 4000 Safety and E-tested. 3700 E-tested.
Sam
91 318is - M50NV (gone)
85 - 325
Old 05-22-2012, 07:27 PM   #2
SamE30e
SamE30e's Avatar
Forgot to state OBO.
85 - 325
Old 05-22-2012, 11:57 PM   #3
car_nut15
This car is super clean and looks like its got 100k on it if not less!
car_nut15 is offline   Reply With Quote
Old 05-24-2012, 09:30 PM   #4
SamE30e
SamE30e's Avatar
Exhaust leak fixed, put on another exhaust manifold with some new OEM gaskets. Quiet as a mouse.
85 - 325
Old 06-01-2012, 09:13 PM   #5
SamE30e
SamE30e's Avatar
Just professionally polished and waxed the car, including the headlights. Looks amazing
Price drop $3600 Safetied and E-tested.
-Sam
85 - 325
Old 06-09-2012, 07:02 PM   #6
SamE30e
SamE30e's Avatar
Sold!
85 - 325
