Old 05-02-2012, 03:09 AM   #1
egye30
egye30's Avatar
Random E30 M20 Parts here
Hey I've got a couple parts sitting around that were for my m20, which i trashed for an M52, i figure these might be of some use to somebody on here, prices are obo shoot me offers on PM
325 Yellow label DME (0 261 200 380) $20
M20 Airbox with MAF $20
"i/is" intake manifold complete with throttle body, fuel rail+Design-II 4-pintle 18.25 lb/hr 43.5 psi injectors (a common inexpensive power upgrade for m20s).
Injectors: Factory injectors are barely adequate to even feed a stock motor when they're new, chances are they aren't feeding enough fuel above 5500 any more. You will want to upgrade your injectors before doing any other upgrades. Any other worthwhile modification will max out your stock pieces and be theoretically useless. Cheap replacements include stock pieces from an M50/S50 motor (E36 2.5 and 3.0, rated 17.5lb/hr) and Ford V8 (Mustang/Crown Vic/etc, rated 19lb/hr). Either set will do the same thing, but using the M50/S50 ones is a little easier because they are all Design II type, meaning the fuel sprays out of 4 pintles instead of 1. Better atomization.
Let's say $100obo
got a pile of other stuff that i'll eventually sort through when i have some time.. but that is all for now
thanks
egye30 is online now   Reply With Quote
Old 05-02-2012, 08:23 AM   #2
FWIW I don't believe this is true. Everyone seems to say it, but no one seems to have tested it. When I installed an M30 AFM and K&N cone filter on my car I also installed a WB O2 to see how the engine would adapt to the mods. When I first drove the car after I swapped parts it was evident that the car was getting more air as the AFRs were reading leaner than they were with the stock airbox and AFM. However after a few km of driving the DME adjusted the fuel trim and the AFRs were normal. Then I did some pulls up to 6500rpm. At WOT near redline the AFRs were in the low 13s which is fine for a n/a car. Now this isn't to say the injectors weren't near 100% duty cycle but even with increased air flow my old, dirty, stock injectors were able to flow enough fuel up to redline.
All of that being said....
GLWS
The 19# injectors are a good mod for anyone who's looking to get a MarkD chip.
Old 05-07-2012, 01:45 AM   #3
egye30
egye30's Avatar
bummpp
Old 06-05-2012, 02:38 PM   #4
egye30
egye30's Avatar
bumppp
Old 07-11-2012, 08:11 PM   #5
flex 54
Hi do you still have the m# 20 intake??
flex 54 is offline   Reply With Quote
Old 07-11-2012, 09:07 PM   #6
egye30
egye30's Avatar
yes i do
Old 07-11-2012, 09:28 PM   #7
flex 54
Ok perfect Pm your info to me You around on Sat? Or Sun?? Send directions Thank's
Old 07-12-2012, 01:49 AM   #8
egye30
egye30's Avatar
PM'd, Thanks
Old 07-14-2012, 07:34 PM   #9
egye30
egye30's Avatar
All Sold! Please close thread
Old 09-21-2012, 11:02 PM   #10
flex 54
Part's finally installed Many thank's
