Old 04-17-2012, 02:13 PM   #1
Stefan11
E30 won't run, no spark, no fuel.
I haven't done much to my E30 since fall and now it doesn't run. There is no fuel or spark. I jumped the fuel pump relay and I have fuel pressure. The car is an 86 with the sensors on the bellhousing. I swapped out the two sensors and nothing has changed. Before I delve into the car and its problem, does anyone have any quick ideas? What seems most important is that BOTH spark and fuel pressure are affected. One day the car ran, the next day it didn't......
Thanks in advance
Stefan
Stefan11 is offline   Reply With Quote
Old 04-17-2012, 03:43 PM   #2
El Gato Liso
El Gato Liso's Avatar
fuse 11
R.I.P. E30
Old 04-17-2012, 03:53 PM   #3
Main Relay (engine bay)
Fusible Link
Fuse (Call all)
Bad ECU
Crank Sensor
These are potential issues that you need to troubleshoot and eliminate one by one in a no start case with no spark or fuel.
Basically ECU is not getting the signals it needs to send spark and trigger the fuel pump.
Old 04-17-2012, 04:05 PM   #4
Ceeker
do you hear the fuel pump engage with the ignition on. Bad fuel pump will give pressure but maybe insufficient.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 04-17-2012, 04:14 PM   #5
Wouldn't cause no spark if it was the pump...
Old 04-17-2012, 04:29 PM   #6
Stefan11
The fuel pump is okay, I have pressure when I jump the relay. I have changed the crank position sensor. I will search and find the main relay and fuseable link. Can I assume that the main relay is controlled by the key? Where in the circuitry is the fuseable link? I ask because I do have power to the fuse panel.
I am away from home and won't get back to the car until this week-end. It would be nice to have the 325 serviceable once again!
Old 04-17-2012, 05:10 PM   #7
Stefan11
I checked all the fuses however I will check fuse #11 again
Old 04-17-2012, 10:40 PM   #8
matty.dc
matty.dc's Avatar
It will most likely be your crank position sensor. I would start by checking the resistance on that sensor(supposed to be around 550ohms I believe). The symptoms are the same. It cuts fuel and spark at the same time. If you were to check your injectors for a pulse from the DME and it was absent, that would for sure tell you it is in fact the CPS.
2013 Ford Edge - Daily Driver
Old 04-17-2012, 11:29 PM   #9
InfiniteDice
14 Years with the E30
InfiniteDice's Avatar
Let's not forget that the sensors on the bell housing look for the little magnet on the flywheel. If that's missing it won't run.
But yeah, check the fusible link in the trunk, one quick way to do that is check for volts on the small lead that comes off the battery, disconnect it from the terminal under the hood on the passenger side firewall... then test to ground.
Old 04-17-2012, 11:30 PM   #10
InfiniteDice
Also if it's automatic it could be the park safety switch.
Does it have an OBC with the start code flashing? lol
Old 04-18-2012, 11:23 PM   #11
E30M42cab
Parts Hoarding Specialist
E30M42cab's Avatar
Can you do a stomp test on a 86?
Grow up and move on.
Old 04-19-2012, 06:50 AM   #12
Stefan11
What is a stomp test?
Old 04-19-2012, 07:35 AM   #13
El Gato Liso
turn key on into accessory
stomp on the gas pedal 5 times
and the Check Engine light on the cluster comes on, and flashes, the number of blinks it makes is equivalent to a number. it read out fault codes, if there are any.
its pretty cool...helped my dumbass out after cutting of my diagnostics port -_-
R.I.P. E30
Old 04-19-2012, 07:59 AM   #14
Stefan11
I will try the stomp test this week-end......
Old 04-19-2012, 09:05 AM   #15
Deetow
If it Returns 1-4-4-4 it means it has no saved faults.
Deetow is offline   Reply With Quote
