Old 02-18-2012, 05:05 PM   #1
slemmer
Driving in the fast lane
slemmer's Avatar
Check engine light on e90
My buddy's e90 suddently had his CEL come on after driving it this morning. The engine sounds rough at idle and seems to go away if I increase the RPM. I hooked up my OBC-II diagnostic tool to see what code would come up and nothing shows.
Is there a newer version of the OBC for 2007+? Unless it's some other engine fault that the OBC scanner cannot see and requiring a visit to the dealer or indy.
Any ideas?
'15 Ford F150 Lariat SCSB 4x4
'04 645cic
'00 740i Sport
Old 02-20-2012, 01:00 AM   #2
Revision2
Revision2's Avatar
I admit I don't know too much about OBD or the more technical parts of the engine but it might be worth checking the air filter and MAF sensor especially if he's running a K&N w/charcoal delete. It might not be the MAF sensor since you got no codes but if you're checking the air filter anyway you may as well. Another suggestion is to PM Jon @ Bimmersport or one of the RMP guys to see if they have any suggestions.
Revision2 is offline   Reply With Quote
Old 02-20-2012, 08:56 AM   #3
slemmer
slemmer's Avatar
He's going to change the spark plugs first to see if it makes a difference then try a coil. Failing that it's a visit to Rocco tomorrow.
'04 645cic
'00 740i Sport
Old 02-20-2012, 05:02 PM   #4
Revision2
Revision2's Avatar
Cool. I'd be interested to know what it ends up being so I know what to test if it ever happens to me.
Old 04-25-2012, 06:39 PM   #5
DimSumE90
Any ideas?
I could have it diagnose, let me know.
drop me a line.
www.littlebimmer.com
DimSumE90 is offline   Reply With Quote
Old 04-26-2012, 07:19 AM   #6
Dinanstu
Confirm that your code reader is "seated" properly in the port. Could be a faulty sensor within the system somewhere (radiator etc).
Sounds like a proper($better$) code reader and indy is in order...
(coils, O2 sensors, MAF would be picked up by the basic code reader...)
Please let us know what the mystery is!!
