Old 04-09-2012, 11:49 PM   #1
Daonhathai
Daonhathai's Avatar
Difference between M52B28 motors?
Hi guys, I'm looking to purchase a motor of a member here and he's got an M52B28 from an E36 328. I'm going to be swapping it into my E39 528 and was wondering if there are any differences I should be aware of. What's parts will I need from my old motor in order to get the donar one to swap in?
All I've come up with so far is the mounts and the oil pan are needed from the 528 block in order to get the 328 to fit?
Daonhathai is offline   Reply With Quote
Old 04-10-2012, 01:36 AM   #2
JINT
JINT's Avatar
M54B28 is too expensive?
1990 M5 Euro
You wash your car like it was your firstborn child, you tend to its needs like it was your own body, you protect it like it's your family, then you drive it like you stole it
JINT is online now   Reply With Quote
Old 04-10-2012, 01:40 AM   #3
Daonhathai
Daonhathai's Avatar
It's my daily, don't need anything fancier than stock. lol
Old 04-10-2012, 05:45 AM   #4
El Gato Liso
El Gato Liso's Avatar
oil pump sump or whatever it is...
***E30 part out to come. Gimme a PM for any inquiries!***
Old 04-10-2012, 12:02 PM   #5
JINT
JINT's Avatar
oh my bad for some reason i thought E39 came with M54 already
1990 M5 Euro
Old 04-11-2012, 03:06 AM   #6
Daonhathai
Daonhathai's Avatar
Can anyone confirm?
Old 04-11-2012, 11:58 AM   #7
ScotcH
Weren't all e39 528s m52TU engines (ie, dual vanos)? If so, I don't think you can swap in an e36 M52, which is a single vanos iron block.
Btw, there is no m54b28 ... it's m52TU and m54b30 (or 25)
Edit ... guess not. Had no idea the e39 went that far back.
Old 04-11-2012, 08:41 PM   #8
Eurostyle
Eurostyle's Avatar
Put it this way, there are 2 types of 528's; 96-98 (single vanos) identical to any E36 328, and 99-00 dual vanos, identical to any 328 E46. Same motor as far as block/head/intake, other then that almost everything is different from 3 to 5, and it ALL has to be swaped out!
Eurostyle is offline   Reply With Quote
Old 04-11-2012, 09:24 PM   #9
mhackley98
mhackley98 is offline   Reply With Quote
Old 04-11-2012, 11:03 PM   #10
Balatch
Ok guys BOTH cars are 1997's.
What accesories DON'T need to be switched over? Is changing the oil sumps a must? I'm curious now to!
Balatch is offline   Reply With Quote
Old 04-11-2012, 11:38 PM   #11
Eurostyle
Eurostyle's Avatar
If you read the last 2 post, it might blow you mind!
Old 04-12-2012, 03:42 AM   #12
Daonhathai
Daonhathai's Avatar
Well, if the block and head are the same, it shouldn't be a problem because I'll have the complete engine from the 5 series to strip the accessories and whatnot from.
Old 04-13-2012, 11:53 PM   #13
Daonhathai
Daonhathai's Avatar
So to save myself of having to get an engine hoist and all that, I'm deciding to just replace the head... Anyone shed any light as to how to set the timing or keep everything in place from moving around while the head is removed?
Old 04-14-2012, 01:30 PM   #14
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
I guess there's a reason your buddy did the work so "cheaply."
Old 04-15-2012, 04:52 AM   #15
Daonhathai
Daonhathai's Avatar
Well, in his defense, he did warn me that the head had small hairline cracks in it after he resurfaced and inspected it. I was trying to save a few bucks from having to replace the head at the time. I don't think the issue has anything to do with my friend, but more so fault on my end.
