I am planning an engine swap so all of my m20 turbo stuff will be for sale.
I have a running turbo car, so everything you could imagine for a running car.
ebay manifold modified for 38mm external waste gate. 350
ebay intercooler 18x12x3 80
3" downpipe with provision for waste gate to dump 100
holset h1e 18^cm3 300
-4an feed line, -10an drain line 80
welded oil pan for turbo drain 250
fittings for oil feed from pressure port on block 10
black powder coated charge piping and couplers 100
HKS ssqv bov 25
MS 2.2 with waste spark, GM coils, MSD wires 300
boost, oil press, water temp, egt pro sport gauges 120
.140 MLS headgasket 100
metric blue head bolts 40
would like to sell as a whole but will part out most likely
all parts are still on the car but will take apart as stuff sells
dont be afraid to pm me to ask anything
edit: will be adding more parts later today
I should mention the MS is a plug and play unit made by rs4pro
all you need to do is wire up the IAT
few other parts
B&M oil cooler, SS lines and nec fittings to use with factory oil filter housing 250
adjustable FPR, bolts into stock fuel rail, looks identical to stock unit. 50
