Old 03-27-2012, 02:29 PM   #1
New Style BMW Wheel Locks
Not sure if many know about these, I only recently found out about them. After hearing about recently stolen wheels, these might help a little.
Part#
36-13-6-792-849 SET WHEEL LOCKS MSRP $90.60
You can get them cheaper online or thru Mike @Maranello
Be careful not to buy the ones for the newer X5,X6,F30,F10s, as they are not 12x1.5mm
These have a spinning outer cap, which prevents a simple wheel lock remover tool from grabbing the outside edges and be able to remove it. I'm sure it won't stop a thief completely, but it should slow them down a great deal if they are expecting to easily remove them using a traditional lock remover tool.
Realistically if a thieve has enough time, they will get what they want.
Old 03-28-2012, 12:42 PM   #2
nate_s89
Thanks for the info, definitely picking up a set.
nate_s89 is offline   Reply With Quote
Old 03-28-2012, 02:15 PM   #3
tchung
Just be carefull about the fit of these new style wheel locks for aftermarket wheels or older style BMW alloy wheels. The head of the bolts and the key is larger in diameter and they might not fit into the small holes of some wheels.
I have one of these new style wheel locks on my E90. When the tire shop try to install aftermarket wheels and winter tires on the car with these new wheel locks, the key got stuck in the bolt hole and the shop spent a long time to extract them. Eventually, I have to use just regular wheel bolts.
tchung is offline   Reply With Quote
Old 03-29-2012, 08:17 PM   #4
This is true, they are bigger.
I didn't have any problems using them on my CSL reps or OEM Contours, but they don't fit my track wheels D-Force LTW-5s.
Old 03-29-2012, 08:24 PM   #5
cormier
cormier's Avatar
After seeing this thread, I'll be picking up a set for sure http://www.maxbimmer.com/forums/showthread.php?t=149628
Old 04-14-2012, 10:25 AM   #6
moto-menace
moto-menace's Avatar
Cool. Does anyone know if there is this style (or any type for that matter) of wheel lock available in extended lengths to accommodate wheel spacers? I would be all over these but I am thinking of widening the stance of my car in the near future so I know I will need longer bolts.
[IMG]
moto-menace is offline   Reply With Quote
Old 04-14-2012, 02:18 PM   #7
BimmerboyPH
BimmerboyPH's Avatar
Those are the biggest POS out there!!!!!! They break, in the wheel lock and your ****ed!!! If you have a car with them on, swap them off right away!
88 325is- written off
89 735i 5 spd- traded
89 325is m50 swap- sold
92 325is- sold
97 328is- sold
00 Land Rover Disco- sold
07 328i- sold
84 325e- track car, in progress........ SOLD!
87 325is- FOR SALE
98 328is- Current Daily
BimmerboyPH is offline   Reply With Quote
Old 04-14-2012, 03:25 PM   #8
Sounds like user error to me, or you have an mechanic that doesn't know what a torque wrench is...
