01-20-2013, 05:58 PM
#136
Car: BMW 318is
01-20-2013, 05:59 PM
#137
Car: BMW 318is
Tuesday, January 8, 2013 --
Finally got the engine in!
Started by getting the cross member set in. Torqued every single bolt to spec. I was worried about having problems with the steering knuckle but I used a air gun to push it on the steering column.
Cut my copper fuel lines and placed rubber fuel hoses at the ends.
Then finally. It was time to put the motor where it belongs. I had to remove the harness off the engine.
NOTE** For those using AKG E30/M50 ENGINE MOUNTS. You may have problems aligning them up with the engine arms if you place them to the cross member like I did. I recommend leaving them loose on the member and let the weight the engine place them properly.
My painter looking impressed by his job
01-20-2013, 06:00 PM
#138
Car: BMW 318is
Wednesday, January 9, 2013 --
Minor work but got some stuff done today. I connected up all my rear brake lines at the joints and made sure they were tight. Also got my UUC SS clutch line hooked up to the slave on the transmission.
Worked on lengthening the wiring to place the diagnostic in original E30 location.
Z3M Shifter with the UUC DSSR
NOTE** The DSSR is really tight fit to where it meets with the shifter.
Installed and got the engine ground finished.
M52 headers clear the subframe and sway bar
AUDI A4 Brake booster clears the manifold without shaving off the fins.
Test Fit
01-20-2013, 06:01 PM
#139
Car: BMW 318is
Friday, January 11, 2013 --
Got my front bags today. My rear bags are on but not done, pics of the rear will follow soon.
I'm going to be installing mine a little different than the DIY that White325is has.
Instead of the using the adapter tube that comes with the kit, I started off by cutting the strut tube flush with the spindle. Then I messed around for about 1 hour cutting and grinding the inside of the spindle so the bag strut can slide into the spindle like they do on VW/AUDI applications. Once, the diameter of the spindle was wide enough, I slide the strut inside and voila. That'll be welded eventually.
I just need to clean up the spindles before they get welded.
Wednesday, January 16, 2013 --
I got her all wired up, cranked it without fuel for a couple of minutes and then she started easily. I took about 2-3 tries before she actually started. My friend which was filming ran out of space on his as soon as she started. So this is a video we took moments after.
It's currently running without a proper tune. Just basic Turner M50 chip that was in the ecu when I got it. She sounds good considering the fact that I've never rebuilt an engine nor have I ever timed a BMW Engine.
I love the backfire on the header.. Flame
http://www.youtube.com/watch?feature...&v=aLgWujE5-YE
01-20-2013, 06:02 PM
#140
Car: BMW 318is
Friday, January 19, 2013 --
Today I knew my friend was coming by the shop (he's a welder) so I prepared my knuckles by cleaning off any dirt and rust. Shortened the adapter tube and got that welded all around the knuckle. Next was to slide in and weld the actual strut body to the adapter tube. Paint to follow, get the top plate reduced in diameter because the one that comes with the airlift kit is way too big. Once that's all done, I can place it on the car,get everything hooked up and see how this baby airs out.
Here are quick pics I took.
01-21-2013, 06:31 PM
#141
Car: Ugly M50 swapped E30
The bags look good duder. I'm thinking I'm just going to come to Montreal and drive your car when it's on the road and judge the air ride for myself. It can sit on H&Rs and Bilsteins til then.
Also: it's not the headers that have trouble clearing the subframe, it's the downpipes which have to go on crazy bad angles. (which messes with your exhaust flo)
Originally Posted by 411
01-21-2013, 06:49 PM
#142
Car: BMW 318is
01-21-2013, 07:43 PM
#143
Car: e36 m3
Awesome work, I love the detail! Can't wait to see it finished.
01-22-2013, 07:45 PM
#144
Car: BMW 318is
01-23-2013, 08:28 AM
#145
Car: many
I am loving this build!
everything is so clean, and crisp and well..clean!
what part of montreal are you in?
01-24-2013, 07:09 PM
#146
The well-dressed, almost homosexual district.
01-24-2013, 09:28 PM
#147
Car: 84 S52 e30/330ix e46
Originally Posted by mtlbloodshot
The Z3M shifter is too long from the ball to the selector rod and causes the DSSR to sit at an angle which faces downwards. It comes into contact with the guibo and does not allow the transmission flange to spin freely. Looks like the Z3M shifter is not good for 24v swaps cause with the M42, I didn't have or maybe notice any problems. Going to get a 1.9 Z3 shifter or if anyone has another suggestions. I'm open to them.
Do you have a picture of the back bracket where the carrier attaches to the chassis? You have that bracket piece eh? I have a similar problem and think I'm going to move that whole bracket (and carrier angle therefore) upwards by drilling another hold higher up for mounting the bracket.
No idea on feasibility yet, I haven't tried it but and meaning to get around to it at some point... Or you could cut up your guibo :p
Nice job on the rest of the stuff!
01-25-2013, 11:07 AM
#148
Car: BMW 318is
This kid is too weird.
I thought about that but even by making a higher hole, the top of the bracket touches the top of the transmission tunnel. What I did is, sold my Z3M shifter and got a Z3 1.9 shifter. It doesn't touch but just sucks that I lost the shortness of the Z3M shifter.
01-25-2013, 11:16 AM
#149
Car: many
St-Denis Street/Ville Marie?? lol
either way, part of my heart belongs in MTL...I find people are passionate about traditional quality work there...must be a european thing.
01-25-2013, 11:30 AM
#150
Car: BMW 318is
I don't live in a homosexual area. I live in an Italian area. Max is just jelly that he doesn't live here where everything is better. Women, night life, cars,
