Old 09-01-2011, 12:44 PM   #1
#SaveTheManuals
BMW recalling E46 3 Series models over faulty tail lights
http://ca.autoblog.com/2011/09/01/bm...y-tail-lights/
Vehicle Make / Model:
Model Year(s):
BMW / 325I
2002-2005
BMW / 325XI
2002-2005
BMW / 330I
2002-2005
BMW / 330XI
2002-2005
Manufacturer: BMW OF NORTH AMERICA, LLC
Mfr's Report Date: AUG 25, 2011
NHTSA CAMPAIGN ID Number: 11V438000
NHTSA Action Number: 2 Investigations found (View)
Component:
EXTERIOR LIGHTING:TAIL LIGHTS
Potential Number of Units Affected:
241,000
Summary:
BMW IS RECALLING CERTAIN MODEL YEAR 2002-2005 325I, 325XI, 330I, AND 330XI VEHICLES MANUFACTURED FROM SEPTEMBER 1, 2001, THROUGH MARCH 1, 2005. OVER TIME, RESISTANCE IN THE ELECTRICAL CONTACTS MAY CAUSE ONE OR MORE REAR LAMP FUNCTIONS (TAIL LIGHT, BRAKE LIGHT, AND/OR TURN-SIGNAL), WITHIN THE VEHICLE'S BODY PANEL, TO STOP WORKING.
Consequence:
INTERMITTENT LIGHT OPERATION REDUCES THE ABILITY TO WARN OTHER MOTORISTS OF THE DRIVER'S INTENTIONS. THIS COULD CAUSE A VEHICLE CRASH WITHOUT WARNING.
Remedy:
BMW WILL NOTIFY OWNERS, AND DEALERS WILL REPAIR THE VEHICLES FREE OF CHARGE. THE SAFETY RECALL IS EXPECTED TO BEGIN DURING OCTOBER 2011. OWNERS MAY CONTACT BMW CUSTOMER RELATIONS AND SERVICES AT 1-800-525-7417.
Notes:
OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
'12 M3 6MT Alpine White + Fox Red Extended | '09 328i 6MT Space Gray + Black
Old 09-01-2011, 01:34 PM   #2
Ahctuning
Ahctuning's Avatar
If that's an issue with the oem tails what about the ones who have upgraded to led tails? can anyone tell from the short problem description of whether the issue is in the factory connectors or oem lamp assembly???
Ahctuning is offline   Reply With Quote
Old 09-01-2011, 08:18 PM   #3
BimmerGuys
BimmerGuys's Avatar
Tail light assembly failure caused by overheating of the electrical pin, as fas as i know.
Sell My Car Fast
BimmerGuys is offline   Reply With Quote
Old 09-01-2011, 08:52 PM   #4
Very common problem with e46; my buddy did a tonne of these when they were rampant. Apparently it is the circuitry in the tail light panel that shorts and the bulbs stop working properly. new backing is required and also a repair.
It has an over heating issue.
Old 09-02-2011, 12:17 AM   #5
gnome
on the roam
My E46 front corners melted last summer, had to replace with new sockets and lense assembly. Sounds similar but my issue was front corner only so far.
Old 09-02-2011, 01:08 AM   #6
Dissembler
Dissembler's Avatar
this happened to my 330i 2 years ago. Had to replace both tail light boards, they were around $200 a piece or something, don't remember the exact cost.
S52 E30
Dissembler is offline   Reply With Quote
Old 09-02-2011, 09:32 AM   #7
damameke
If you still have the receipt, you can try claiming it from BMW...
I have this intermittent issue, so its good that BMW is doing
the recall on this issue.. i wonder what prompted this for its a known issue from E46 owners.....
thanks dbworld4k for posting this...
Old 09-02-2011, 06:38 PM   #8
crxgsr
BMW
I thought there was also a previous TSB, in which the tails weren't grounding properly, and a "fix" available. (basically adding a thicker negative ground wire).
Edit: nevermind, I see they mention this in the article:
"Previously, BMW issued a technical service bulletin concerning a certain eight-pin connector which would overheat and melt under extreme electrical load. BMW dealers corrected the issue by adding additional grounding to the circuit. It's unclear whether this remedy will also be applied to the recall."
Old 09-02-2011, 06:53 PM   #9
noodles101
ΛΦΕ
noodles101's Avatar
what about E36s~!!! ... same problem with E36s as well
Old 09-02-2011, 07:11 PM   #10
u can try and state a claim but I highly doubt it. if it ain't in the nationwide agenda you're sol. sorry..Perhaps the very late model years had this but not enough to generate a recall. I'm sure if BMW could get away with not having this they would. But due to MTO/DMV they would get roasted with heavy fines due to the nature. Someone obviously blew the lid off this case in order to generate such publicity. they also don't need the negative press. BMW is not keen on recalls unless someone has blown the whistle. There is usually lengthy investigation before the come out with such an announcement. I know when I worked for a dealer the e46 M3 cars were having knocking engines at 10-20k. At first they thought it was neglect so the customers engine would sit in the bay of the shop for weeks. Finally new motors arrived for a few customers and the old engines were recrated and sent back to head office for inspection. After this they found out it was a faulty oil delivery system and made a batch of new oil pumps and called everyone back in with their M3's to get them changed before they had to swallow engine replacements. Cheaper to change pumps then replace engine. so it saved them tonnes of money.
Old 09-02-2011, 07:53 PM   #11
busamoose
http://www-odi.nhtsa.dot.gov/recalls...intVersion=YES
http://www.bloomberg.com/news/2011-0...nction-2-.html
http://www-odi.nhtsa.dot.gov/acms/do...romPublic=true
busamoose is offline   Reply With Quote
Old 09-02-2011, 08:04 PM   #12
the first two links are not working. :-)
Old 03-22-2012, 10:30 AM   #13
damameke
I received this recall notice late Nov 2011 and car is in Maranello today,
according to SA, they will replace the wiring especially the gounding cable...
Old 03-22-2012, 12:50 PM   #14
This happens on e36's too. I cleaned out the electrical contacts (sandpaper), this solved my problem.
Old 03-22-2012, 11:01 PM   #15
Blackedout95
The real sad part is they included these models for rear tails and not the front HID light cars that have the same issues as ones they covered. Guess that would cost too much!
When you have an HID issue it is either an expensive bulb or ignitor/control module...sucks.
E46
