Old 03-21-2012, 04:03 PM   #1
Robhaskell
Robhaskell's Avatar
"new" (to me) 2004 325i - Sluggish?
I just acquired a 2004 325i, my first 4 door sedan. I have been driving E46 coupe's all my life and this is the first time I am driving a 4 door.
The car runs very smoothly, drives like a limo in some respects and the braking is good.
However, when I lift my foot off the gas, the car seems to drag a bit and slow down more quickly than my 33ci. Overall it does seem to be a heavy car, even from acceleration and steering perspectives.
Is this my imagination, or is the weight of the 4 door the cause?
Brakes are not rubbing, no noises at all coming from the car, and all else seems normal. Transmission behaves as it should with no issues apparently there.
Comments? Suggestions where to look for issues?
Thanks in advance. Rob
Robhaskell is offline   Reply With Quote
Old 03-21-2012, 07:31 PM   #2
blk3
blk3's Avatar
are you sure the brakes are not slightly draging at all?
Old 03-22-2012, 01:30 AM   #3
jabela
The difference you feel could be due to different gear ratios and/or transmission programming.
http://www.bokchoys.com/differential/GearRatios.htm
www.maisonapothecare.ca
Old 03-23-2012, 01:34 PM   #4
Tires
Wheel bearings
Diff ratios
Transmissions
Sticking caliper
etc etc
No 2 cars feel the same. Your 325i is actually lighter than your 330Ci btw.
Old 03-25-2012, 09:30 PM   #5
hamant
Tires
Wheel bearings
Diff ratios
Transmissions
Sticking caliper
etc etc
x2.. its probably in your head but if not there could 101 reasons.
Is there actually a problem, or do you just 'feel like it drags' post
hamant is offline   Reply With Quote
Old 03-25-2012, 10:36 PM   #6
Blackedout95
Guess it depends where in the band and what gear you are in as well. I too drive a e46 4 door and hey, its 4 doors with 180-190 hp, not exactly expecting lightning in a bottle lol
E46
