Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 09-23-2012, 06:58 PM   #121
BMe30
all by chance...
BMe30's Avatar
^^^^ all that work... Failed.
Had it all hooked up and was running so lean that the afr maxed out. Im assuming there were a few leaks around the connections.. They were tight but not that tight.. Im going to try again later if i can find the time with some pipe clamps.
The good news is that the fg plenum is much more secure and does not rub anywhere.
So i took out the icv stuff and plugged all the vac openings for it to try again later.
Did find a little vac leak from one of the old lines im using for the fpr log.. Nothing to worry too much about.. But ill get that fixed up too
Gone but not forgotten
Old 09-27-2012, 08:50 PM   #122
BMe30
all by chance...
BMe30's Avatar
Well... Had a little dyno run at RMP today...
Plugged in the tunerpro rt software and the files purchased from Bmwconnect.
Did some fuel tuning first... Car was still running lean but did a baseline pull of 65whp
Made more changes to the fuel mapping got as high as 70whp... We could not get the fuel to add no matter how high we made the adjustments...
So Rocco had some s52 injectors.. Swapped them in... And put some new plugs... Did a pass 80ish whp..
Did a little more fuel/air adjustments and some timing advancement... 99.6whp...
Thanks to Rocco rmp and bmwconnect and anyone else who helped out!
Old 09-27-2012, 10:08 PM   #123
Those numbers are pretty low... a healthy M42 should be making ~120whp
Does the dynapac read lower than a typical dynojet?
Either way... big improvement over the baseline... I'm looking forward to taking it for another spin.
Old 09-27-2012, 10:31 PM   #124
BMe30
all by chance...
BMe30's Avatar
I have no clue the difference between the dynos... But still.. A 33whp gain
Yes about 120whp on a newer healthy m42..
Mine has 290000 and im sure its been worn out... Never checked the compression either. All in all car pulls a lot better... Need to do a little street tuning for casual driving.
Im sure there is a few more hp that can be squeezed out of it.. But later on
Old 09-30-2012, 10:02 AM   #125
mr ilia
Adding power is always good, bu your numbers do not make sense at all.
1 - With the he stock TB setup, did your engine "pull hard"?
2 - Can you feel the difference "before" and after the "tune"?
3 - What is "butt dyno" telling you, if thar is better now with the ITBs than when it was with single TB?singe?
Old 09-30-2012, 11:15 AM   #126
BMe30
all by chance...
BMe30's Avatar
1.stock tb with stock chip no... Stock tb with dinan clone chip pulled better
2.itbs before tune running on dinan chip pulled better but not WOT bc it would lean out. 20% - 80% throttle car drove and pulled great... After we tuned the itbs added bigger injectors and got the motor to run safe afr it pulled even better. There is still some fine tuning to be done on the tq/hp curve.
"butt dyno" feels much more responsive and pulls better than stock.
There were a couple of people who drove the car before... When they drive it again they'll feel the diff.
And as i said.. It is not fine tuned yet... I might be able to get maybe 5 more hp but what im looking to get is a better tq/hp curve.
I may have it tuned a bit more by the fall cruise or the next autoslalom event. come and see how it is...
Old 09-30-2012, 02:19 PM   #127
mr ilia
where you able to get the dyno chart?
Old 09-30-2012, 02:46 PM   #128
BMe30
all by chance...
BMe30's Avatar
Having trouble uploading it from my phone... Ill try later when i get home later this evening.
Old 09-30-2012, 08:38 PM   #129
BMe30
all by chance...
BMe30's Avatar
here it is..
as you can see there is still some fine tuning needed with the tq/hp curve and im sure there is a little more hp to gain as well. we only had 2hrs before i had to leave for my baby classes to get this working in a safe afr.. in that time also included trouble shooting the stock injectors.. installing the s52 injectors and new plugs.. having the engine cool between a few runs.
Old 10-01-2012, 10:37 AM   #130
DR.ZED
Interesting torque curve!
Cam G.
85 325e M5
07 Honda Shadow Spirit 750
Old 10-01-2012, 10:56 AM   #131
BMe30
all by chance...
BMe30's Avatar
Yeah thats pretty funny... Lastnight i was looking at the curve and the fuel/timing map in that area... It showed a higher fuel and timing in that range. So i smoothed out the fuel as rpm rises in that area and retarded the timing a bit but kept it all within safe limits and rpm..
Loaded up that update this morning and my butt dyno noticed a better pull in that range.
Old 10-03-2012, 10:47 PM   #132
SamE30e
SamE30e's Avatar
Interesting build. Kudo's for tackling it yourself.
I must say that torque curve is interesting.
85 325 - Turbo M52B28.
Old 10-03-2012, 11:18 PM   #133
BMe30
all by chance...
BMe30's Avatar
Thanks!
Yeah 15ftlbs lost... I messed with it street tuning the fuel and it seemed better. Ill know on the next dyno session.
Also i have been thinking of another plenum design.. One that is more common and a proven design. Something like this...
Old 10-06-2012, 01:05 PM   #134
BMe30
all by chance...
BMe30's Avatar
So i did that dyno day today... So from that first dyno pull to todays i was messing around with some tunes and this is what i got with a failing fuel pump..
Ill go back once my new tre-340 fuel pump goes in
Old 10-06-2012, 05:40 PM   #135
Flattest torque curve ever...
