Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 09-12-2012, 11:12 AM   #106
Originally Posted by BMe30 View Post
I checked on a few computers, iphone and ipad.. The pics are there. Is anyone else having issues with the pics?
No problems here.
Old 09-12-2012, 05:51 PM   #107
voluted
voluted's Avatar
I had an issue yesterday but it's fine now. Looks like a fun project and I can't wait for sound clips!
Old 09-12-2012, 06:26 PM   #108
BMe30
all by chance...
BMe30's Avatar
I had a little time tonight to apply first layer of fg to join the 2 parts...
In my haste i may have not put enough hardener...
Here is my tps set up... Japan to german...
Closed itb...
Wot itb...
Little off on the voltage from stock.. But i can adjust later..
Gone but not forgotten
Old 09-14-2012, 07:24 PM   #109
BMe30
all by chance...
BMe30's Avatar
Well i trimmed the sides and started to fg them...
Its a little cool out so i brought out my old school heater to help things out a bit..
I'm going to do a little more tonight... It should be ready to start installing tomorrow morning if there are no little holes that i may have missed
Old 09-14-2012, 11:04 PM   #110
BMe30
all by chance...
BMe30's Avatar
Well.... I couldnt wait till saturday... Got everything hooked up... Tps, vac lines, afm mount... Just one little problem.... The brake booster line....
Im going to try and tuck it somehow..
Getting pretty tired though... Maybe ill start fresh in the morning...
Old 09-15-2012, 07:44 AM   #111
defaultName
You are sooooo close!
Looking forward to seeing this tomorrow!
Old 09-15-2012, 07:50 AM   #112
Git 'er dun!
Old 09-15-2012, 09:02 AM   #113
BMe30
all by chance...
BMe30's Avatar
I was able to tuck the brake booster line lastnight... Hooked everything up and started her up.
Little rough so i adjusted the idle trim. I looked at the afr and showed 10:1.... Odd.
I ended up taking it for a boot to the gas station.. Put some gas in and checked the tps... Was showing 5v the whole time...
I did shorten the tps wires before i wrapped them. But i have a feeling somethings a miss.
I didnt build this to run the icv... I think im going to fab it in later.
Going to check it all out now...
Old 09-15-2012, 12:42 PM   #114
BMe30
all by chance...
BMe30's Avatar
Yeah when i taped the tps i broke the connection...
So i fixed that with a little solder.. Taped it.. Reinstalled and got a proper voltage reading.
Took it for a drive.. Not bad at all.. Afr seems to be the same as before... Idles around 14.7 but jumps to 15 and low as 14.2...
Drivability its really touchy to ease into gears..
The fg air box rubs a bit on the hood ribbing and the brake booster...
This set up it a lot smoother than the one i did last year with the abs plastic parts.. Also it dosent fall off past 4500rpm as before... But you can feel that there isnt much there.
See you at the autoslalom
Old 09-16-2012, 06:23 AM   #115
BMe30
all by chance...
BMe30's Avatar
So i was out last night drove to cambridge... Car did good on the hwy and the city.. On the way back home i wanted to check out the afr readings a bit more... As stated before the afr wasnt too bad for normal driving not hitting WOT. On the hwy i hit WOT and as soon as i did afr reads 16+:1
Yeah... She needs some fuel tuning....
Old 09-16-2012, 06:50 PM   #116
BMe30
all by chance...
BMe30's Avatar
Today was an interesting day at the autoslalom... Couldnt go WOT bc i lean right out. But did really well without using WOT. Was still able to hit high revs without leaning out.. Stayed in second gear the whole time..
I must say with that limitation of no WOT made for a smooth lap... Good learning tool.
But i think i had enough learning for one day.... Time to tune the beast!
Old 09-19-2012, 09:57 PM   #117
BMe30
all by chance...
BMe30's Avatar
Well i need to mod a few things before i get this thing tuned.
1st will be to mod the fg plenum so it wont rub on the hood, the ps resevoir, and the brake booster.
2nd i have to install the icv... So i found this and saved me a lot of fab time...
Here are some install pics...
Old 09-20-2012, 04:32 PM   #118
mr ilia
Where did you get this from?
Old 09-20-2012, 05:51 PM   #119
BMe30
all by chance...
BMe30's Avatar
Cdn tire... Plumbing dept
Old 09-23-2012, 05:05 PM   #120
BMe30
all by chance...
BMe30's Avatar
Did a little more work today..
Set up for the icv is done.. But i was short in one length when i got the vac lines.... Tip of the day... If you think you have enough, get more.
I also shaved off some areas on the fg plenum that was rubbing.. And added a bit more fg to the main inlet..
