Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 04-11-2012, 11:00 PM   #76
That cam cover looks awesome!
Old 04-11-2012, 11:29 PM   #77
DIY
Permanently Dirty
DIY's Avatar
Awesome! keep it up! what kit is that?
Old 04-12-2012, 01:43 AM   #78
El Gato Liso
El Gato Liso's Avatar
ah man...the paint went all crinkled on that valve cover...that sucks!
gonna repaint it?
R.I.P. E30
Old 04-12-2012, 08:37 AM   #79
Bosch 55 pin DIYPNP kit from diyautotune.com
gonna repaint it?
No way man, it took me forever to put each one of those wrinkles on there...
Old 04-12-2012, 09:52 AM   #80
InfiniteDice
14 Years with the E30
InfiniteDice's Avatar
So you bought the pnp ms kit.... nice I want that as well, do you get the tunes and stuff with that (do you get all the same things as the pre-built unit?)
Old 04-12-2012, 11:13 AM   #81
The MSPNP is a different product than the DIYPNP. The MSPNP runs off of the MegaSquirtPNP B8793 ECU while the DIYPNP uses the Microsquirt module. Since the MSPNP is a true PNP kit it comes with the maps pre-loaded as well as on a CD. This kit doesn't come with the maps preloaded (because I have to build it) or on a CD however they have them here on their website with the application guide
http://www.diyautotune.com/diypnp/ap...m20b25-mt.html
Old 04-13-2012, 10:39 AM   #82
Car started up first try last night on the DIYPNP kit which was nice. Only problem is that the WB O2 wasn't reading in the tuning software so I'll have to double check the wiring for that, and I still need to get a variable TPS. But it starts, idles and drives so I'm in good shape
Old 04-13-2012, 10:53 AM   #83
BMe30
all by chance...
BMe30's Avatar
Cant wait to see the dyno sheet
Gone but not forgotten
Old 04-13-2012, 11:12 AM   #84
For the stock motor?
Old 04-13-2012, 12:39 PM   #85
BMe30
all by chance...
BMe30's Avatar
Thought you had the built motor turned over.....
Old 04-13-2012, 02:28 PM   #86
lol that'd be nice! I'm still waiting for parts. You will definitely see some assembly pictures when the time comes
I still need to figure out what I want to do for the exhaust... I'm thinking y-pipe to 3" with a cat, resonator and muffler 4 sections connected by 3 v-band clamps for easy removal.
Old 04-13-2012, 03:28 PM   #87
BMe30
all by chance...
BMe30's Avatar
That should sound awesome. You should hear mine.
Old 04-13-2012, 03:56 PM   #88
karmatose
164.3ci Of Fury
karmatose's Avatar
Headers of your choosing to x-pipe to glasspacks (instead of a cat) to Stebro catback would be my choice.
Old 04-13-2012, 04:39 PM   #89
Car still needs to pass emissions so I'm going with a high flow cat. And I'm going with single pipe to reduce weight.
Old 04-19-2012, 09:11 AM   #90
Unfortunately there isn't much to update on this project. Just a few small things.
Firstly, I am going to be picking up the parts I need to start assembling the motor from Han Solo next weekend.
Secondly, last weekend I went to balance the pistons and when I weighed them they were all within 1 gram of each other so I didn't even bother touching them. I still need to balance the rods, hopefully that will be a bit more exciting.
Thirdly, I was thinking about the adjustable cam gear yesterday and how I would go about making adjustments. All the after-market gears have a degree scale etched into them, but I don't have the tools to do that. I thought about just printing a scale that I could just laminate and glue on and use with the existing timing line on the gear, yeah kind of ghetto but it would work. Then I thought about how pretty much all mechanical timing adjustments rely on the accuracy of the eye of the person making the adjustment. I figured it’d be nice if there was a quick, easy, and above all fool proof way to make timing adjustments. I came up with this concept…
At this point you might be wondering what those extra holes are for. Looking at the timing gear I figured that the manufacturing tolerance of the gear was at least as good as (or better) than the accuracy of the human eye so why not use the physical geometry of the gear to dictate the timing adjustment. Obviously when I go to machine the gear I will verify if my assumption was acceptable or not. This picture will give you a better idea of what is going on…
As you can see, my idea was to use the spokes of the timing gear to adjust timing. The holes in the plate will be reamed to 6mm to have a nice snug fit for a 6mm dowel pin. That way I will be able to insert a dowel pin into a hole, loosen the screws around the outside and rotate the gear until the dowel pin contacts the spoke. One spoke is used to set the orientation of the gear back to stock timing and the other spokes can advance or retard the timing 1 degree per spoke. So this layout gives me +/- 5 degrees of timing adjustment, however the holes could be revised to give any combination of advance and retard. Hopefully it works!
That’s all for now folks!
