Old 03-12-2012, 04:32 PM   #16
Originally Posted by InfiniteDice View Post
haha... yes I talked myself backwards there, what I meant was,
DIAMETERS:
BIGGEST --------------- Smallest
Exhaust Port.....Gasket.....Head
We're not talking a wall here, more like a very small .5 - 1mm lip.
That way the flow steps out to the larger area... when/if you get back flow it will hit the lip but that's not important.
That makes more sense
That's what I did as well, except I left the port diameter in the head about 2mm smaller all the way around to account for the ability of the exhaust gasket to shift. I don't want any overlapping of the gasket and the port in the head.
Old 03-12-2012, 04:35 PM   #17
Not sure if you mentioned it, but you probably also want to port match the intake manifold ports to the gasket also.
I remember doing that when I built an m20, no idea if there were any gains from it, but it didn't hurt.
Dare I squeeze
Old 03-12-2012, 06:15 PM   #18
E30M42cab
Parts Hoarding Specialist
E30M42cab's Avatar
Steve, you should put this m20 in a boat!
This will help you determine how much chain you will need for it to safely reach the bottom:
Just kidding, good work
1986 E30 325e (killed)
1986 E30 325es (died)
1988 E30 325i (rotted)
1992 E34 525i (sold)
1992 E30 318i (cabrio, Dad's)
1989 E30 325i (Mom's)
1991 E30 318i (cabrio, summer car)
1991 E30 318is (Winter car)
1992 Euro M5 (driveway decoration)
1994 E36 325is (driveway junk)
Old 03-12-2012, 07:24 PM   #19
I did mention it. That's the plan
I'll use the 325e block and crank as a boat anchor unless someone wants to buy them. I also have two 325e heads.
Old 03-12-2012, 08:11 PM   #20
BMe30
all by chance...
BMe30's Avatar
May i recomend?.....
GsxR 750 & 1000 from 2000-2003
750 & 1000 are essentially the same
80mm spacing between bore centres
48mm ID, 54mm OD at inlet
42mm ID, 48mm OD at exit
You might want to use those bc they can seperate individually and respace as needed...
Old 03-12-2012, 10:11 PM   #21
That's good info. I'm definitely looking for individual, individual throttle bodies lol. Thanks Bruno.
Old 03-12-2012, 10:43 PM   #22
BMe30
all by chance...
BMe30's Avatar
And here is another helping hand for you....
http://www.knfilters.com/search/prod...x?Prod=RC-2344
Old 03-12-2012, 11:35 PM   #23
Nah when I go itb I'm definitely going with itg socks
Old 03-12-2012, 11:43 PM   #24
DIY
Permanently Dirty
DIY's Avatar
Baller! I can't wait to hear this scream!
If your gonna get new rockers why not new springs too? Then some 9000 RPM fun
Old 03-13-2012, 06:44 AM   #25
BMe30
all by chance...
BMe30's Avatar
Nice! I was looking for something like that to go over velocity stacks.. But couldnt find a good source for stacks with a bug screen
Old 03-13-2012, 08:12 AM   #26
I am getting new springs, but just oem ones, not upgraded ones. I ended up buying a Schrick 284/272 cam and although upgraded springs are recommended I've seen the same cam used on stock springs go up to 7500rpm. I'm not really interested (at least not yet ) in going over 7000rpm since the stock tach only goes up to 7000rpm and without some port work and itbs the head most likely won't flow enough to be useful past that rpm anyway.
Yeah I was thinking about that the other day too, I'd want a few sets of stacks with different lengths and then try each on the dyno but they can be expensive. I was thinking about making my own, put some thin walled stainless tube on a lathe and use some sort of mandrel to flare it out then roll the edge. As I said that's going to be a whole other project....
Old 03-13-2012, 08:54 AM   #27
BMe30
all by chance...
BMe30's Avatar
This might save you a little time and money....
http://forums.neons.org/viewtopic.php?t=294784
Old 03-13-2012, 10:05 AM   #28
InfiniteDice
12 Years with the E30
InfiniteDice's Avatar
http://www.vibrantperformance.com/main.php Amazing array of parts.
Bought my whole exhaust system from them, decent prices, good items and Canadian company.
Old 03-13-2012, 10:35 AM   #29
This will come in handy if I end up deciding to do my own exhaust.
Old 03-13-2012, 10:53 AM   #30
DIY
Permanently Dirty
DIY's Avatar
Hey Bruno you try that aluminum soilder yet on your intake (from vibrant)? If it works steve could prob use it too..
http://www.aptuned.com/18960
