Old 04-07-2012, 01:31 AM   #1
gotcurry
gotcurry's Avatar
E36 steering rack info needed!
My 328is is in need of a steering rack. I was wondering what I can fit in there in terms of other models such as z3,e30,e46 etc.. and what would be the advantage/disadvantage of going with them. Also r rebuild racks any good in terms of cost/quality. Any info is greatly appreciated.
Thanks.
[| aFe CAI || 3.38 LSD || M50 SWAP || SuperSprint Exhaust || H&R + Bilstein Sports |]
gotcurry is offline   Reply With Quote
Old 04-07-2012, 07:36 AM   #2
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
Non m and 96-99 m3 are same, 95 m3 slightly quicker ratio, z3 less turns due to less travel. Stay away from e30 racks, they require modification and are a downgrade. E46 racks dont fit to my knowledge.
Old 04-07-2012, 08:49 AM   #3
gotcurry
gotcurry's Avatar
Awesome.. thnx for the info
Old 04-07-2012, 11:46 AM   #4
Eurostyle
Eurostyle's Avatar
If E46 rack fits on E30, has to fit the E36! They are almost identical in design. 330's after 9.01 had the 3.0 turn ratio that was shorter then other E46's...
Eurostyle is offline   Reply With Quote
Old 04-07-2012, 11:50 AM   #5
gotcurry
gotcurry's Avatar
can you elaborate more on the ratio and what it does?
Old 04-07-2012, 11:57 AM   #6
Eurostyle
Eurostyle's Avatar
Pretty much means how many turns of the steering wheel you need to go from full left to full right. The smaller the #, the more responsive the steering is!
Old 04-07-2012, 12:24 PM   #7
gotcurry
gotcurry's Avatar
you got any i can use???
Old 04-07-2012, 01:02 PM   #8
Ya e46 racks should fit, I believe I've also seen modification to use z4m racks if you want to go that far :p
Z3/02+e46.330/e36m are ideal in that order IMO from when I was looking around
Old 04-07-2012, 01:49 PM   #9
gotcurry
gotcurry's Avatar
thnx for the info. now i just need to find one
Old 04-07-2012, 02:37 PM   #10
You're looking used/cost effective? Or rebuilt?
Old 04-07-2012, 03:29 PM   #11
gotcurry
gotcurry's Avatar
i was considering rebuilt but wasnt sure how much it would cost me
Old 04-07-2012, 03:41 PM   #12
Axxe
Axxe's Avatar
Learn something new everyday.
Old 04-07-2012, 04:25 PM   #13
egye30
egye30's Avatar
He's deff right about that, this is a stock e30 rack vs an 04 330 (e46) rack going into my e30, courtesy of Mr Eurostyle himself. Very similar in design, veeery different on the road.
egye30 is online now   Reply With Quote
Old 04-09-2012, 10:16 AM   #14
SiR
Vtec just kicked in
e46 racks bolt right in.
even z4 fits(just).
even your stock lines bolt right up .
oem homologation ftw
and the rack ratio means a heck of a lot more than the turns to lock. you want to concentrate on the ratio if you are looking to change things up.
example above the later model 330 rack have a 13:1 ratio. (which is actually faster than the e46 m3 rack which is around 14.5:1 iirc)
You can find good shape used e46 racks at a few of the bmw parts guys around these parts.
-||Old Crayons||-
Old 04-10-2012, 01:56 PM   #15
gotcurry
gotcurry's Avatar
even z4 fits(just).
thnx for the info.. i am actually shopping around for them.. i called a few places but have not been able to get a proper response.. if anyone has a steering rack from an e46 late model 330 or m3 or even e36 pls let me knw.
